clutch feels depressed
Old Aug 22, 2009 | 12:37 AM
vnarang's Avatar
vnarang
Default clutch feels depressed
my clutch feels depressed. it happened about 3 hours ago. I was going home and noticed i felt different, im still able to drive it. I push it and it goes in like 1/2" - 1" and am still able to shift. i already had my slave cylinder replaced once under the recall. im thinking it could be that, or maybe clutch fluid?
should i take it to nissan? im also due for an oil change (3k miles/3month) if that means anything. also this is my first manual transmission car, i thought for a second maybe the clutch could be going out.
thanks.
Old Aug 22, 2009 | 04:44 AM
What year Z?
The slave cylinder was replaced when?
Old Aug 22, 2009 | 11:48 AM
vnarang's Avatar
vnarang
Originally Posted by davidv
What year Z?
It's an 07 Z. These Z's were the one's that had the recall, and I had mine done maybe about a year ago.
Old Aug 22, 2009 | 12:12 PM
vnarang's Avatar
vnarang
HALP!
Old Aug 22, 2009 | 01:44 PM
vnarang's Avatar
vnarang
Okays. So today I tried to start my car and leave, i noticed the clutch felt depressed even more. on top of that, when i started my car i couldnt get out of first, and back into neutral or reverse. I decided to stop my car, since it was on a flat surfact i tried to put in netural again, which i was able to do so, and now its just sitting on my driveway with the handbrake. clutch burnt out?
Old Aug 22, 2009 | 01:50 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
sounds like the slave
clutch fluid is easy to check - its a sealed system so if it were gone, you would see the puddle under the car
Old Aug 22, 2009 | 02:21 PM
vnarang's Avatar
vnarang
Damn. What would it feel like if the clutch was burnt out? and how long do you think an average clutch lasts(i know it varies)? my car has 22k miles on it.
Old Aug 22, 2009 | 02:26 PM
Z1 Performance
Former Sponsor
no one can tell you how long it will last - it depends on how it's driven. I could kill a clutch, even a brand new triple disk, etc etc, in an afternoon if I had my heart set on doing it
Old Aug 22, 2009 | 04:08 PM
vnarang's Avatar
vnarang
so its not a burnt out clutch then?
Old Aug 22, 2009 | 04:59 PM
Nissan may give you another slave cylinder if it has been less than 12 months-12,000 miles. Clutch wear is on your dime. Good luck.
Old Aug 22, 2009 | 07:30 PM
blastoff99's Avatar
blastoff99
Prozac.
Old Aug 23, 2009 | 05:06 PM
vnarang's Avatar
vnarang
Old Aug 27, 2009 | 04:11 PM
350ZthatsMe's Avatar
350ZthatsMe
just pull the clutch pedal back up with your left foot.... the pedal sinks when the fluid gets hot (ie. traffic, or drifting)... the pedal won't come back up when the fluid cools down.. you just have to pull it back up... then you'll be as good as normal..
Old Aug 27, 2009 | 04:31 PM
zippo07's Avatar
zippo07
same problem as mine, i went back 3x at the dealer and they can't figure it out. what i did i check the fluid and guest what its way 2full, after removing some fluid, it work.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
