A/C issue
Old Aug 26, 2009 | 11:00 AM
Axel's Avatar
Axel
Default A/C issue
I used and went through the the search thread; there does not appear to be a similiar issue regarding my A/C problem. At least from my opinion.
A/C issue. I previously used the A/C with no shut down problems,,,worked as advertised. Yesterday, on the way home, used the A/C, got home and went to shut it off, and the unit would not shut off, the blower went to high and was blowing warm air into the car.
The A/C button was selected to off and the outside vent light was lit on the middle ****. I shut the car off and went about my business. Used the car again, started the car up, the heat/air unit was off. Used the A/C again and no joy trying to shut it off. I turned ***** this way and that to get it to respond differently. It would either go to A/C or when attempted to shut it off, it would blow hot air.
Read through the search threads and made sure the white plug was plugged in and I didn't notice any breaks or issues with the ribbon connector. Anyone else experience this issue??
Any input to a fix before I take it in to get looked at? Thanks in advance.
Old Aug 26, 2009 | 11:57 AM
vthao's Avatar
vthao
So...your A/C works when it's on and blows hot air when off?
Old Aug 27, 2009 | 02:25 AM
Axel's Avatar
Axel
In simplified terms, yes. The heat/A/C will not shut off. I have to shut the car off to "reset" the system. Could it be the white box need to be replaced?
Old Aug 27, 2009 | 08:56 PM
nosurf2day's Avatar
nosurf2day
I would venture to say yes, sounds like the brain in the white box went bad.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
