Passenger Door AC Vent broke
Old Sep 11, 2009 | 10:26 AM
phenom85Z's Avatar
phenom85Z
Default Passenger Door AC Vent broke
    Old Sep 11, 2009 | 10:52 AM
    Xzero's Avatar
    Xzero
    I suggest ordering the part & when it comes in, take a look at it & see how it attaches. Then take the door panel off, remove the broken vent, install the new one, put the door panel on again & you'll be set!
    Old Sep 11, 2009 | 11:58 AM
    Waiz's Avatar
    Waiz
    Take a look at this diagram on the Courtesy site:
    http://www.courtesyparts.com/350z-pa...5_846_857.html
    It looks like it's not installed with any particular bolt, so it may be held in by tension only.
    Old Sep 29, 2009 | 04:04 AM
    falseidols7's Avatar
    falseidols7
    i had this problem just yeserday.... remove the rubber piece thats on the outside frame of the door.. if you look inside theres a screw in the center holding it in place use a phillips head screw driver to hold it in place so you can unscrew the vent counter clockwise.. take it out and put the clip back onto there and put it back and ur done
    Old Dec 30, 2012 | 11:49 AM
    Doc B's Avatar
    Doc B
    Default Genius!
    Took about the same time to remove & install the new vent as it did to turn on the computer and type this reply! BRAVO!!
    Rev_Night
    Nov 7, 2020 06:00 PM
    Gruppe-S
    Body Interior
    13
    May 16, 2016 10:42 PM
    Sleeper_Z
    Sep 30, 2015 10:25 AM
    Fixxxercask
    Drivetrain
    Sep 28, 2015 11:15 AM
    samansharif
    Sep 25, 2015 12:31 PM
