wierd sound?
Old Sep 14, 2009 | 05:47 AM
TJGILROY's Avatar
TJGILROY
Default wierd sound?
so i think it's my rotors...they only do it every now and then but when i'm cruising around 35, it's a faint wheel noise coming from the front, i got my breaks done about 15000 miles ago but nobody said anything about my rotors needing resurfacing or replacing...any ideas of what it may be?
Old Sep 14, 2009 | 06:30 AM
Brrcats's Avatar
Brrcats
is it a constant noise? an intermittant noise? a squeel, a grind?
gotta give a little more information
Old Sep 14, 2009 | 07:25 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Sep 14, 2009 | 07:41 AM
TJGILROY's Avatar
TJGILROY
sorry, it's a every now and again noise, but like a high tone metal wobbeling on something noise...like something is not straight in the front...hard to describe but it's always when i'm at a constant speed around 35mph or so
Old Sep 14, 2009 | 11:41 AM
vthao's Avatar
vthao
Rotors don't usually make noise when you're not on the brakes. It may be the dustshield touching the rotor, or even a bearing.
Old Sep 14, 2009 | 11:44 AM
TJGILROY's Avatar
TJGILROY
never thought of the bearing....it might be that
Old Sep 14, 2009 | 12:20 PM
TJGILROY's Avatar
TJGILROY
""I recently purchased a 2004 Nissan 350Z. When I went in for first Lube, Oil, & Filter I was told the vehicle had NO Grease zerts to lube the suspension and stearing parts. I was told that the replacement parts (once the origional parts wore out) came with grease fittings, but that the Factory put no grease points on the origional parts. This seems crazy to me. Anyone got an answer, or explaination for this? Any alternative to waiting while your car parts wear out from lack of lubrication?""
I saw this somewhere...could it be something just wearing out???
Old Sep 14, 2009 | 03:12 PM
vthao's Avatar
vthao
That'll make clicking sounds...like a dead strut.
Old Sep 15, 2009 | 06:30 AM
TJGILROY's Avatar
TJGILROY
oh, ok...well i know not to believe everything i find on the internet, it's just like a low humm sometimes at a certain speed coming from the front wheels...any more input?
Old Sep 18, 2009 | 07:37 PM
nismoz1260's Avatar
nismoz1260
This is true most factory ball joints and tie rods come prelubed and cannot be serviced....this is good and bad.... they also use slick plastics in the socket which do not require lube and don't make squealing noises when dry. If you think its a bad idea listen to most mid 90's fords trying to manuver in a parking lot.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
