rust on wheel hub flange
Old Oct 23, 2009 | 08:19 AM
HXS's Avatar
HXS
Default rust on wheel hub flange
is it safe to use a rust remover, like naval jelly, to remove rust on the wheel hub flange (NOT on the rotors)?
or should i just leave it alone?
Old Oct 23, 2009 | 11:10 AM
ImWeeZzel's Avatar
ImWeeZzel
y wouldnt it be? if you don't then those parts will deteriorate quicker
Old Oct 23, 2009 | 11:39 AM
Wire brush and a coat of WD-40. It will be fine.
Old Oct 23, 2009 | 11:58 AM
ImWeeZzel's Avatar
ImWeeZzel
Old Oct 25, 2009 | 07:51 AM
HXS's Avatar
HXS
thanks
i'm guessing PB Blaster instead of WD-40 will be fine?
Old Oct 25, 2009 | 09:05 PM
350ZTheStandard's Avatar
350ZTheStandard
I am getting approx 5whp from the rust on mine, i have slotted & drilled rotors, with rust. Think that makes a difference???
Old Oct 25, 2009 | 09:19 PM
JasonZ-YA's Avatar
JasonZ-YA
Wire brush then rust converter (sold at autozone, etc)...once dry your good, or you can spray with primer.........cover studs, dont get paint on the threads..
this stuff:
http://www.autobodytoolmart.com/klea...2-p-12824.aspx
answered here too:
https://my350z.com/forum/7231046-post5.html
update:
see post 5 here:
https://my350z.com/forum/wheels-and-...ml#post7229635
-J
Old Oct 25, 2009 | 09:29 PM
350ZTheStandard
^ sure if you waNt to lose the 5 whp.
Old Nov 15, 2009 | 12:37 AM
BlackSpec02's Avatar
BlackSpec02
I think I will also pick up some of that anti-seize lube because the backs have a lot of rust on the hub and my spacers were tough to get off.
Old Nov 15, 2009 | 06:02 PM
ImWeeZzel's Avatar
ImWeeZzel
mud on tires gives you extra traction and increases acceleration
Obadabot
Jun 18, 2023 11:31 PM
