Do you REALLY want one of these? I mean how hard is it to remove one simple oil pan bolt? Did you read the warnings? I'd be scared my oil was pouring out of my car while driving down the highway.
Drive carefully at all times, and if you run over any foreign object on the road, pull over and check the valve for any damage or leak.
N-Series valve(with Nipple to accept hose) is not recommended for passenger cars with low ground clearance.
So don't get the one with the hose and our cars' drain plugs are not exposed anyways so the ground clearance issues is not applicable. We have the plastic undercover.
