low idle oil pressure and engine smell burn???
Old Nov 29, 2009 | 01:33 AM
sssmasss's Avatar
sssmasss
Default low idle oil pressure and engine smell burn???
i read alot about low idle pressure...
and some people posted :
idle above 14
2k rpm above 43
6k rpm above 57...
my car has always been above 30 or at 30 when idling... reasonly i changed from going to the dealer for oil change to diy.. i used mobil 1 5w30 fully synthetic and nissan oil filter. just 2 weeks after oil change the oil read somewhere below 30 at idling..but definitely above 15.
is this normal? i think it is normal according to what i read.. but it is true? is what i read above true?. idling above 14???
second problem.. i noticed that my car smell engine burning if i go up the hill and step on the gas pedal to force my car to run faster. i checked and do not see any oil leak... and as long as i dont force my car then it will not produce burning smell like...
is this normal? please let me know...i want to check my head gaskets.. but since it doesnt produce smell when i baby the car... so... i am not sure..
please help
Old Nov 29, 2009 | 05:49 AM
Specs above from service manual. The pressure gage inside the car is not the most accurate tool.
Old Nov 29, 2009 | 06:01 AM
Jay'Z's Avatar
Jay'Z
If you think your oil pressure is low try a thicker oil, 10w30 or 10w40
Old Nov 29, 2009 | 02:59 PM
sssmasss's Avatar
sssmasss
what different does it make? i am sorry i am a total noob at oil and car. hehehe...
thinner oil vs thicker oil? that is the different?
dealer oil always use 5w30?.. does it affect my performance? if switch to 10w30? i am living in san diego, california btw...
thanks
Old Dec 5, 2009 | 11:35 PM
sssmasss's Avatar
sssmasss
anyone has any idea about my second problem? smelling oil burn if i step on it too hard?...if i take it slow then there is nothing... thanks
Old Dec 6, 2009 | 01:40 AM
SchismX's Avatar
SchismX
10w30 is fine. That is what I use in mine. Your oil pressure is normal.
lapham3
Oct 7, 2022 03:15 PM
liqalu04
Jan 2, 2022 12:58 PM
apex locator
Jul 23, 2021 02:27 AM
