airbag light-reset procedure will not turn it off
Old Mar 20, 2010 | 06:50 PM
ashtrojan2008's Avatar
ashtrojan2008
Default airbag light-reset procedure will not turn it off
Here's the deal. Due to an incorrect alarm wiring diagram, my driver airbag was deployed(hit me in the face ). The power was sent to the bag at the steering wheel after the module. Of course when the bag went off it melted the connectors. I bought a new bag and new connectors and soldered the connectors in. Put it all together and did the procedure... light doesn't go away. The procedure has worked for me before when the crash sensor got unplugged so i know it works. The airbag light is flashing a code for the driver airbag, not for a "deployed airbag". This makes me think it isn't the module, but i have no idea what else to check. I would like to check the resistance on the airbag i purchased but i do not want to risk deploying it by making contact with a multimeter. Is there a way to test the airbag? Is there any way to tell if the module is bad? Any suggestions?
Next thing i will do is place resistors in place of the airbag and try the reset.
Thanks
Ross
Attached Thumbnails airbag light-reset procedure will not turn it off-040-2-.jpg   airbag light-reset procedure will not turn it off-iphone-011.jpg
Old Mar 21, 2010 | 03:28 PM
ashtrojan2008
does anyone know if cipher will reset the module? A guy on ebay will reset the module for $35. Has anyone had theirs reset? Does anyone know how to reset hard codes?
While on topic of cipher, can speed limiter/rev limiter be changed? or do you have to do the osiris reflash?
any help would be appreciated.
ross
Old Mar 23, 2010 | 10:02 PM
ashtrojan2008
bump for any ideas. Does consult II clear hard codes?
ross
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
