Popping noise when shifting to neutral
Old Oct 28, 2003 | 08:36 PM
Strife350z's Avatar
Strife350z
Unhappy Popping noise when shifting to neutral
Does anyone have this problem on their MT?
When moving at low speed in 1st or 2nd, say around 6 mph (crawling in a parking lot), and you engage the clutch to shift into neutral, do you get a loud "pop" noise?
I notice it most when going into my garage (i have a steep driveway, but a shallow garage space):
i get into first and stay at a really low speed (engine is under load), i head up my driveway until my front wheels are in my garage, then i push in the clutch... then i get a POP noise
please help
Old Oct 29, 2003 | 02:45 AM
jeffa55's Avatar
jeffa55
Yes, I have the same thing (and heard it because I too had a steep driveway leading into a garage). It seems to be worse when engaging the clutch with the engine under load (ie - going up a driveway and then pushing the cluch in to stop in the garage). Mine was a pop and a couple of ticks afterwards (sounded like something was 'slowing down'... I posted this long ago and took it to the dealer - end result is that this is 'normal' and don't worry about it.
Old Oct 29, 2003 | 04:55 PM
Strife350z's Avatar
Strife350z
Default it's normal?
i hope so too... but it's just that the noise is quite unsettling... especially since it's SO loud and it actually bucks my car a little bit
to me, and correct me if i'm wrong (i'm a newbie MT driver), it seems like i'm unloading the driveshaft while there's still a fair amount of torque being transferred through it... thereby causing a reflex action to occur causing the popping noise
Old Oct 30, 2003 | 08:33 AM
Strife350z's Avatar
Strife350z
Anyone else have this problem?
Seems to make me worry when there is a forum of 10000+ members and only 1 other person is having this problem
Old Jun 25, 2004 | 11:06 AM
Azeotrope's Avatar
Azeotrope
Mine makes a "pop" noise sometimes when I depress the pedal. It doesn't matter if the car is off or I am shifting. It's more frequent now, and I will have it looked at when it goes for the first oil change.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
