I think I really fugged up!!
Old Apr 15, 2010 | 06:17 AM
macjac69's Avatar
macjac69
Default I think I really fugged up!!
Ok I was wiring in some interior accent lighting and I think I had the two way switch wired wrong, anyways when I applied power something went wrong. The lights I wired in came on for a few seconds then went off, I didn't hear a pop or any other noticeable sound.
Afterwards my power windows and A/C won't work when power is applied, some of the guages are inop also.The big kicker is that the car won't start now either, the starter will turn over but I get no spark. I spliced into a wire that was under the dash that powers the NO2 in the car (didn't know that until I started troubleshooting) the wire was taped into a 12v+ at the driver kick panel fusebox. Before I did this everything worked perfectly.
I pulled every fuse no blown fuses, as far as the relays, or breakers I don't know where to begin, I didn't find any fusible links that were blown either. I checked the lighting I was installing by just applying it directly to the battery and it still works. The car is an 03 touring ed. I think.
Old Apr 15, 2010 | 06:34 AM
RandyK1's Avatar
RandyK1
Did you check the fuse box in back of the battery?
Old Apr 15, 2010 | 06:40 AM
marques1's Avatar
marques1
Did you not unhook the battery cable before messing with your cars wiring.
Old Apr 15, 2010 | 06:42 AM
macjac69's Avatar
macjac69
Checked fusebox behind battery, yes I disconnected neg. cable while working. I guess one ? is are there any more locations for fuses/relays other than the two under the hood and the driver kick panel?
Old Apr 15, 2010 | 06:51 AM
Waiz's Avatar
Waiz
When ill informed DIY goes wrong...
Old Apr 15, 2010 | 07:50 AM
tylerxfire's Avatar
tylerxfire
ur gonna have to check ur relays id say..does the car have power?
Old Apr 15, 2010 | 08:42 AM
macjac69's Avatar
macjac69
Yep the car has power and the starter turns over fine it just won't fire off. It's something small I think it's just that I don't know the Nissan platform like I know my Supra so isolating it will be a pain in the butt.
Old Apr 20, 2010 | 05:26 AM
macjac69's Avatar
macjac69
Problem was a fuse, overlooked it when troubleshooting, I was very tired when I got to that point. Came back a couple days later and tried it again after some rest.
Clipdin
Mid-Atlantic
Jun 22, 2008 04:30 PM
G352NV
Apr 28, 2007 10:18 AM
