noise coming from rear whenever going over a bump or making a sharp turn
Old Apr 16, 2010 | 06:41 AM
dakota9812's Avatar
dakota9812
Default noise coming from rear whenever going over a bump or making a sharp turn
whenever i go over a bump or make a sharp turn i hear this noise in the rear of my car that sounds like something is bouncing up and down. i checked the stability of my exhaust and it seems fine and i cleaned out my trunk and nothing was loose or flying around back there. when i go over a bump its just a two step noise as if something comes up hits something and comes down. when i turn it usually will make the noise probably about 4-5 times and sounds sort of like a popping noise. can someone tell me the possibilities of what this can be? thanks
Old Apr 23, 2010 | 12:58 AM
Synjn's Avatar
Synjn
Search the forum a bit. You should find some input.
Old Apr 23, 2010 | 07:36 AM
BYL's Avatar
BYL
I think i had a similar issue on my 08. Metallic ticking noise coming from the rear when going over bumps/rough road and turns! I checked and checked under the car, front and rear, etc... Finally, took it to the dealer (under warranty) and after 3 days in the shop and them calling Nissan North America, they hooked up the "chassis Ears" and found the problem. I'm sorry, dude, but i forget what it was...but it was some suspension piece that wasn't properly screwed in. they replaced it, tightened the new one and off on my way I went. So far so good...KNOCK ON WOOD!
Not sure if you're is still under warranty, but from what the dealer told me it was very hard to find although it was very audible and if its true, you may not find it on your own.
Bottom line, its not normal and you should get it fixed.
Old Apr 23, 2010 | 07:49 AM
JasonZ-YA's Avatar
JasonZ-YA
could you call the dealer and have them look up your tech invoice and find out what exact part it was???
-J
Old Apr 23, 2010 | 07:55 AM
JasonZ-YA's Avatar
JasonZ-YA
I have diagnosed issues like this before but never pin pointed what exact point it was and this is why...
FIRST I,
1. inspected everything!! i mean every exhaust hanger, every bushing, every dynamic point under the rear of the car.
2. i then looked for smudges in road grime - as in, if the edge of an exhaust pipe was hitting you can see that there is a smooth spot or lack of road grime from contact versus the near by areas.
then
3. i went to loosening and re tightening/torquing every bolt down there! every suspension bolt, every knuckle to spring bucket/camber arm, rear shock to body 12mm bolts, shock to knuckle bolt - E.V.E.R.Y.T.H.I.N.G......
4. cleaned excessively dirty parts...
I would also use Lithium spray lube at all points of metal to metal contact, etc...
Then magically noises were gone....
-J
Old Apr 23, 2010 | 08:01 AM
Mazinger Z's Avatar
Mazinger Z
I'm having the same problem (it seems like). So far I've only taken off my wheels and re-torqued them, but still having the same sound. Mine is coming from the middle/left/rear of my car. It sounds like a bolt is loose or something. I just got new brakes/pads installed...argh...it's bugging the crap out of me. I have this fear of something coming loose when I'm driving and BAM, my car is skidding down the freeway on it's ***.
*Knock on wood*
Going to jack up the car later and take a real look to see what's up. Man...damn it all to hell !
Old Apr 23, 2010 | 09:06 AM
JasonZ-YA's Avatar
JasonZ-YA
Old Apr 24, 2010 | 11:15 AM
niZam's Avatar
niZam
I've also got a sound when going over bumps. Cant decide if its the axle issue or something else. Metallic in sound, almost like spoons being hit together with a rattle. Its odd, happens on bumps at any speed but if Im on the gas accelerating and hit a bump, no sound. Can the axles rattle over bumps from being too loose?
Old May 2, 2010 | 04:08 PM
jray8's Avatar
jray8
bump
Old May 2, 2010 | 05:34 PM
NewJoyZ's Avatar
NewJoyZ
Might be strut knock. How may miles?
Old Aug 17, 2010 | 09:41 AM
B18CTOVQ35's Avatar
B18CTOVQ35
I'm having the same issue now that we installed my Eibachs...it didnt do it the first ride home but the next day, i noticed it trying to get of the garage. Mine seems like its coming from the front driver side more than it is in the rear. more of a pop pop pop or a click click click how ever you wanna call it. it does it when i turn or even when im going straight. Not sure if something is loose or something is rubbing and getting stuck. We are gonna pull the rims off tonight and i will update once we find out anything.
Old Aug 19, 2010 | 01:55 PM
Lefix's Avatar
Lefix
I kinda have the same problem, small clicking or popping noise.. Not sure what it is but it is only one click, keep us updated!!
Old Aug 19, 2010 | 02:08 PM
bboypuertoroc's Avatar
bboypuertoroc
Sounds like control arms...
Old Sep 6, 2010 | 08:11 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Improperly lubricated rear hub...there was a TSb, common problem with no real consequences othe rthan sound...
Old Aug 28, 2012 | 01:38 AM
dykel3fiddyz's Avatar
dykel3fiddyz
Bringing from the dead. I have this issue along with the axle clicking issue. And my dealership is a P.O.S that wont do a goddamn thing about anything.
ti837
Sep 22, 2015 07:46 AM
CrowzRSA
Sep 21, 2015 04:00 PM
Suffolk350z
Sep 13, 2015 02:43 PM
PureR3d
Sep 10, 2015 06:23 PM
Daniel_dh
Sep 7, 2015 12:56 PM
