failed window?
Old Apr 25, 2010 | 10:06 AM
blackchopper's Avatar
blackchopper
Default failed window?
hi there can anyone help here got a 2004 softop 350z and today one of the windows would not go back up !it went down ok when roof was down but now dead so what to i check for? had to strip door a part to get window back upso if anyone has had this fault before and can help that would be great.
Old Apr 25, 2010 | 10:19 AM
MODDEDZ's Avatar
MODDEDZ
Can you here the motor clicking when you try to roll the window up?
Old Apr 25, 2010 | 10:22 AM
blackchopper
no noise at all and how the hell do you get window up with out striping door apart?
Old Apr 25, 2010 | 10:25 AM
MODDEDZ's Avatar
MODDEDZ
You either disabled window or it's blown.
Old Apr 25, 2010 | 11:01 AM
blackchopper
how do you disable window ?
Old Apr 25, 2010 | 11:04 AM
MODDEDZ's Avatar
MODDEDZ
Certain pattern pressed on your key fob, I believe.
Old Apr 25, 2010 | 11:32 AM
Beast101's Avatar
Beast101
Default lmao *Subscribed*
Same EXACT! thing happen to me. My passenger side window has always went down a little slower than the passenger side. I put the windows down to install some speakers and make sure they dont clip. But they never went back up.
OP, how did you pull up the mirrors, you unscrewed that inner panel, and just pushed them up literally?
Old Apr 25, 2010 | 12:51 PM
Very common. Please search window motor.
Old Apr 25, 2010 | 01:15 PM
Entaille's Avatar
Entaille
your window motors dead or dying. slam the door, beat the panel, and try to roll it back up.sometimes that will shake some of the buildup off and allow it to operate. this is nothing but a temporary thing to get the window back up without taking the panel apart.
ultimately, you need to replace it. they are 180$ or so lifetime warranty at local auto part stores, with a 30$ core refund.
dealerships will offer you a new motor plus install for around 500.. lol
Old Apr 25, 2010 | 03:29 PM
Guilty1s's Avatar
Guilty1s
Are you sure you plugged your window button back in... neither side will control the passager window if the switch isnt connected
Old Apr 25, 2010 | 04:39 PM
Beast101's Avatar
Beast101
Default I'm assuming I did...
originally I didn't have the passnger side plug in. I let the top down for some more air circulation and realized the passenger window was still up. So I unplugged the negative line on the battery then plug the passenger side switch back in. Plugged the battery back up and the window rolled down. Took off the negative battery, installed the speaker. Put the battery back on and the now the window won't go up.
Old May 3, 2010 | 07:40 AM
blackchopper
ok update on window checked fuses all ok if you open roof both windows go down fine but will not go up from then from both driver and passager window switches! so what you think?
Siqcology
Sep 18, 2019 01:45 PM
350z_z33.
Jul 3, 2017 04:01 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
AP350z223
Sep 8, 2015 04:38 PM
