At 50,00 miles. Dealership says coolant and...
Old May 14, 2010 | 09:37 AM
randymack's Avatar
randymack
Default At 50,00 miles. Dealership says coolant and...
Just hit 50k and had my Oil/tranny fluid done. Dealership says My coolant Has to be flushed and my drive belts changed Immediately.
When have you done these?
Old May 14, 2010 | 09:38 AM
MarvinMartian's Avatar
MarvinMartian
Immediately.
Old May 14, 2010 | 09:44 AM
Ruthless18x's Avatar
Ruthless18x
Originally Posted by MarvinMartian
Immediately.
Old May 14, 2010 | 10:16 AM
SFMACGUY's Avatar
SFMACGUY
Old May 14, 2010 | 10:32 AM
lgear080's Avatar
lgear080
is this a joke or a real question?
Old May 14, 2010 | 10:41 AM
JasonZ-YA's Avatar
JasonZ-YA
what does your owners manual say??
from there you decide...
-J
Patsfan83's Avatar
Patsfan83
I changed belts at 27k, Coolant at 30k
I bought the car with a belt already in bad shape so I changed that ASAP. If your belt looks worn, torn, then replace it. For coolant I've been told 30K (part of the 30k service) so I said why not and did it.
Old May 14, 2010 | 10:48 AM
DavesZ#3's Avatar
DavesZ#3
It should have been done a long time ago.
Here, check this... https://my350z.com/forum/maintenance...intenance.html
Old May 14, 2010 | 12:02 PM
Parker01's Avatar
Parker01
I did my belt at 48,000 MILES, the inside of the belt was starting to show small cracks. Belts are cheap but critical... just do it. I got Good Year belts though and did it myself, the stealership wanted double what I payed for the belts.
I need to do my coolant, tranny and diff
Old May 14, 2010 | 01:55 PM
Thanks but do not want to play. Good-bye forever.
Old May 15, 2010 | 04:37 AM
jimbosr1's Avatar
jimbosr1
i bought my z with 38k on it, and my belts needed replacement.i changed the rear diff fluid and the coolant and oil myself.
Old May 15, 2010 | 06:58 AM
Lee R's Avatar
Lee R
This is a repost.
Old May 17, 2010 | 12:07 PM
Bevo's Avatar
Bevo
I changed my oil, tranny, differential and coolant at 30k miles. Belts are going to be replaced soon.
Old May 17, 2010 | 12:24 PM
plumpzz's Avatar
plumpzz
I did it myself, its easier than an oil change.
There is a bleeder on the bottom of the radiator. Just do it when its cold otherwise you'll drain the block and then have fun trying to bleed it. A lot of gunk came out at 35k miles. When its empty, flush some water through and then close off the bleeder. Fill with premixed coolant, burp and you'll be good to go.
Old May 18, 2010 | 08:06 AM
intoZsunset's Avatar
intoZsunset
I change my coolant every 20k or so. I get the belts done every 36k.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Cashwin
Oct 1, 2015 06:36 AM
SharX59
Sep 27, 2015 09:23 AM
