battery problem not 100% sure
Old Jun 12, 2010 | 06:06 PM
NismoZZ's Avatar
NismoZZ
Default battery problem not 100% sure
So i started my Z this morning an it didn't want to start i figured its the battery but im not sure.The reason why is when i got the car to turn on the battery volt gauge is okay just above the line beetween 12 and 16 I haven't driven the Z for two days thats not that long so the problem is not the battery drained from no use. i didn;t leave anything turned on headlights doors ext. i looked at the battery an i can see what looks to be a date on it an it says 01 12 02 T Im pretty sure this is a date an pretty sure the battery is done but that battery volt gauge just makes me think i really hope its not something else (like alternator). Well tomorrow i will take it to get tested battery an alternator and will prob buy new battery. This battery now looks to be the stock one that came with the car its bottom is gray/clear and top is black, i didn't buy the car new i bought it in 2009 its a 2003 350z touring. so if that date on the battery is true then its been 8 years this battery has been working so thats about right for the life of a battery. Has anyone here had this problem or maybe something similar like this with the battery volt gauge or is this gauge not a reliable source for a dying battery. Or if anyone still has thier 2003 350z stock battery can you describe how it looks or if it matches my description any info is appreciated.
Old Jun 12, 2010 | 07:12 PM
johnwigs's Avatar
johnwigs
if it has the 6 screws in the top then it is the stock battery... does it click when you turn the key??? anyways start with the battery... you cant diagnose with out a good battery
Old Jun 12, 2010 | 07:15 PM
NismoZZ's Avatar
NismoZZ
yes it does have screws an the black braket holding it down. Yes it clicks when i turn the key an thanks alot for the info
Old Jun 12, 2010 | 07:19 PM
johnwigs's Avatar
johnwigs
then it is 95% the battery... possibly ground cable or positive cable... highly unlikely... in my 11 years as a tech Ive seen 1 positive cable bad... and a couple ground cables... pretty noticable though... never on a Z or newer than Y2k nissans
Old Jun 12, 2010 | 07:20 PM
Litesung's Avatar
Litesung
try jumpstarting
Old Jun 12, 2010 | 08:03 PM
NismoZZ's Avatar
NismoZZ
thank you so much
Old Jun 12, 2010 | 08:12 PM
johnwigs's Avatar
johnwigs
pretty impressive that the battery lasted that long in the cold colorado enviroment... at least the summers must be bitchin to drive in... I only get a sea level to 5k elevation change in about 30 min drive (got a few mountain roads here)
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
If the battery is that old, it's the battery. Most OEM batteries last about 3 years and that's it. Get a new one.
Old Jun 12, 2010 | 09:01 PM
The battery is 7 years old? Get yourself a new battery for sure.
Old Jun 12, 2010 | 09:34 PM
winchman's Avatar
winchman
The voltage will stay about the same regardless of battery condition UNTIL you put a load on it.
Old Jun 12, 2010 | 09:56 PM
randysduality's Avatar
randysduality
if your car makes clicking sounds when you try to start it, it's most likely your battery is dead. most auto zones will test your battery for free, and even recharge it for you.
Old Jun 12, 2010 | 10:18 PM
POWUH's Avatar
POWUH
winchman has it , you need a new battery
Old Jun 13, 2010 | 01:35 AM
duro78's Avatar
duro78
the stock battery is pretty durable and last very long. 7 years is askin for trouble
Old Jun 14, 2010 | 10:06 PM
NismoZZ's Avatar
NismoZZ
thanks for all ur comments an u were right it was the battery autozone tested it an said one of the battery cells or something was lose an it was reading at 10 volts an dropping so i got a new battery a Duralast Gold it was $94.00 and it did the trick. i was thinking about the optima yellow or red top but i got nothing to crazy installed yet so ill stick will the duralast
Old Jun 14, 2010 | 10:12 PM
NismoZZ's Avatar
NismoZZ
yea the previous owner took very good care of my Z i bought it in 2009 and thats prob y the battery lasted so long.
Old Jul 13, 2010 | 04:47 PM
ImWeeZzel's Avatar
ImWeeZzel
does anyone know the cold/cranking amps? I tried to charge my battery for 5, then, 10 min. nothing, no juice at all. I heard the clicking sound as well.
My 06 currently has the oem battery. I took it to autozone and they didnt wanna look up the info/specs for my battery. They wanted to know the cold cranking amps.
could someone help me? I dont mind buying a new battery, but if mine is still good then its kinda pointless
Old Jul 13, 2010 | 05:42 PM
Is the battery stamped CCA (cold crank amps)?
If it says JIS (Japanese industrial standard) that is not helpful. I know of no accurate JIS to CCA conversion.
Old Jul 14, 2010 | 06:48 AM
ImWeeZzel's Avatar
ImWeeZzel
I looked all over the battery for specs, nothing. I searched but I listened to the advice on here and you guys were right. It needed a new battery, problem solved. Thanks for the response davidv
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
