Flashing Airbag Light - Comes back after reset
Old Jun 13, 2010 | 06:13 AM
Bret86944's Avatar
Bret86944
Default Flashing Airbag Light - Comes back after reset
My airbag light started flashing out of nowhere. I was just driving on the highway. I did the reset procedure and the light will stay off for maybe 20-30 miles, then comes back back while I'm driving. I don't get any code, just 3 seconds on, 2 seconds off, so I'm not sure where to begin troubleshooting. Could it be a loose wire? Any suggestions would be great. Thanks.
Old Jun 13, 2010 | 07:09 AM
marques1's Avatar
marques1
sounds like you will be visiting the dealership. Usually if you do the reset procedure and it comes back on you have some type of issue.
Old Jun 13, 2010 | 02:16 PM
SQBassHead's Avatar
SQBassHead
ive had this for about 1yr maybe 2...lol... i just forgot about it, i never even bothered to search...lol.
but if nobody flames you and tells you to search, then im in for some info... post up what you did to fix it.
good luck op
Old Jun 13, 2010 | 02:20 PM
Waiz's Avatar
Waiz
Check under your drivers seat, there may be something loose and try the reset again.
I would get the light nearly every week until I started storing my foldout sunshade under the passenger seat. I haven't had the light return in nearly 6 months.
Old Jun 13, 2010 | 03:05 PM
evanm's Avatar
evanm
im having the same problem, started about a month ago, did the reset and then it came back in a day or so. not sure what could be causing it so id love to hear if anyone finds out
Old Jun 14, 2010 | 07:54 AM
Bret86944's Avatar
Bret86944
I unplugged the wired under the driver's seat and plugged it back in firmly. Light still came back on... I may leave the wire unplugged and see if that gives me anything different.
If the airbag module is shot would that give me an error code other than the steady flashing?
Old Jun 14, 2010 | 07:56 AM
dbrown's Avatar
dbrown
I was told you have to reset it three times before it will actually stay off
Old Jun 14, 2010 | 07:57 AM
dbrown's Avatar
dbrown
My buddy works for the NIssan plant and he had the same problem he told me he did it one time and then again and once again for the third time and later on he found out it has to be done three times for some odd reason.....
Old Jun 14, 2010 | 08:25 AM
Waiz's Avatar
Waiz
I did the reset tons of times before I stopped storing things under my seat and it went away so this can't be the case.
Old Jun 14, 2010 | 08:27 AM
Bret86944's Avatar
Bret86944
So yours was going off just from stuff bumping the wires? I've been moving my seat around a lot lately. I wonder if that's doing it...
Old Jun 14, 2010 | 08:32 AM
Waiz's Avatar
Waiz
The sunshade was crimping the wires and was a tight fit underneath the seat.
Take a look underneath the seat and make sure you didn't pull any of the cables.
Old Jun 17, 2010 | 03:02 AM
Bret86944's Avatar
Bret86944
Alright, I've reset it for like the 4th or 5th time now. Just this past time I unplugged the cable under the seat to see what happens. The light came on a lot quicker. Maybe there is a bad wire somewhere the is getting bumped loose or something. I still don't really have any idea.
Old Jun 17, 2010 | 07:24 PM
Dan Garcia's Avatar
Dan Garcia
It is very likely that you have a lose wire, I took my z in to the dealership for them to reset the airbag sensor, their diagnostics test determined that it was a lose or broken ground wire behind the stereo which had been installed a couple of weeks before.
Old Jun 21, 2010 | 11:44 AM
Bret86944's Avatar
Bret86944
If it is a loose wire, I can't find it. I tried looking at the electrical crap and I don't really know what I'm looking at. Nothing looked loose, frayed, broken, etc. Unfortunately I'm going to take it to the stealership. I'll bring my vaseline and cross my fingers it's only a couple hundred bucks.
Old Jun 21, 2010 | 12:20 PM
Dan Garcia's Avatar
Dan Garcia
re-setting the air bag light will set you back 92.00 plus tax. they need to do the diagnostic test to be able to pin point the problem.
Old Jun 21, 2010 | 12:35 PM
Bret86944's Avatar
Bret86944
Yeah, I was going to tell them I reset it like 7 times already and that they need to run the diagnostic.
$92 is crap, geez. I can reset it with my key in literally one minute.
loudtoyz
Apr 6, 2023 04:52 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
