just brought my car to the dealership for window problems and....
Old Jun 14, 2010 | 01:57 PM
FairLadyz916's Avatar
FairLadyz916
Default just brought my car to the dealership for window problems and....
I brought my car in this morning car a window problem to the local dealership.
problem was: every time i roll my passenger window all the way up it would automatically roll back down
Problem solution : window motor went bad
now the service adviser just called me back saying my battery voltage is low and if they were to replace the window motor i would need to replace the battery as well too, cause it can disrupt the timing on the window. I thought that was kind of ridiculous so i declined on the battery.
i thought they were just trying to get some money out me since everything was covered under warranty.
anybody know anything about that?? or could help me out on this?
thanks for your help
Old Jun 14, 2010 | 02:20 PM
lgear080's Avatar
lgear080
are you paying the dealership for a new window motor + install?
i have a passenger window motor ready to ship for $100 + Shipping.
DIY!
and you obviously don't need a new battery. dealership fraud as usual.
Old Jun 14, 2010 | 02:21 PM
winchman's Avatar
winchman
That's the kind of stuff that gives dealers a bad reputation. I think you did the right thing.
If the battery has enough capacity to start the engine reliably, it's got more than enough to make the window work properly.
Old Jun 14, 2010 | 02:25 PM
FairLadyz916
everything was covered under warranty so it was free..but they advised me my voltage was low and it can disrupt the timing on my window and it can cause the same problem as before.
Old Jun 14, 2010 | 03:40 PM
winchman's Avatar
winchman
That doesn't make sense. They replaced the window motor because it was bad. Now they're saying "low voltage' will make the new motor do the same thing. Sounds like total BS.
You haven't said anything about having problems starting the car, so I'm assuming the battery is good enough to do that.
Old Jun 14, 2010 | 03:56 PM
FairLadyz916
o yea i never had any type of problems with starting the car..its starts like the first day i bought it..lol..werid thing is that the battery gauge still seems the same as well too..im going to take my car to a buddies shop to test the voltage on my battery.
but yea it totally sounds like BS to me to thats why i declined the new battery replacement.
Old Jun 14, 2010 | 03:58 PM
godzilla619's Avatar
godzilla619
ask for the old motor back to ensure that they replaced it too.
Old Jun 14, 2010 | 03:59 PM
Armed Ferret's Avatar
Armed Ferret
Any chance they're well aware the window motors are a weak point in the car, and are just making something up so that when the next one fails if under warranty still, they can say "oh well that's due to the other problem we told you about but you refused to fix it, so it's not our problem now."
Sorry, been a tinfoil hat night for me.
Old Jun 14, 2010 | 04:17 PM
w0rM's Avatar
w0rM
Good idea
Old Jun 14, 2010 | 05:22 PM
Did they recommend an alignment. Poor alignment has been shown to discombobulate the window motors.
Old Jun 14, 2010 | 05:34 PM
ZKansasZ's Avatar
ZKansasZ
LOL @ davidv comment.
Old Jun 14, 2010 | 06:24 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Alignments are so 90s. Wheel bearings are the new alignments.
Old Jun 17, 2010 | 03:59 AM
s7n03diddy's Avatar
s7n03diddy
i took my car to my friends shop and he also said they could not diagnose my abs/vcd light problem until i changed my battery because of low voltage. apparently when he hooked up the diagnostic machine the only code he was getting is low voltage. i swapped out a new battery and then i got the correct code for speed sensors. replaced them now everything is good. hope that helps.
Old Jun 17, 2010 | 04:34 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
dude - your window is bad when it doesnt move anymore at all...All you need to to do is a reset procedure..
If your window has NO problem going up.. its not the motor.. do the reset procedure and tell the stealership you fixed it in 30 mins...and that you dont need them anymore.. they just want your $$...bet it was a 100 bucks just to "diagnose" the issue...
Old Jun 17, 2010 | 09:17 AM
PerfZ's Avatar
PerfZ
^^^^^^^Exactly. But if he got a free motor under warranty, more power to him and less to the dumba$$ stealership for not knowing about what is probably the most common problem with the car. Jeesh!
Old Jun 17, 2010 | 09:34 AM
MUZZY's Avatar
MUZZY
Your window motor is just fine. Somehow the motor got reset (could be the low eatery voltage problem). You have to open door panel and stick your finger in the panel right behind the motor and locate the reset button. Then hold it while rolled down then again up.
What has happened is that the window motor goes up all the way beyond the stop limit and the safety kicks in and roles it down b/c it senses a resistance in the path (aka A-pillar).
Another reason might be that the sensitivity screw could have wiggled loos making it more sensitive. This will roll the window down whenever any resistance is applied.
lolwatbro
Oct 9, 2021 04:58 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
RyansZ33
Sep 15, 2015 05:54 AM
AP350z223
Sep 8, 2015 04:38 PM
