Valve Solenoid - Timing Control
Old Jul 8, 2010 | 07:53 PM
angel700's Avatar
angel700
Default Valve Solenoid - Timing Control
Hi people, im trying to troubleshoot a bad sensor, i see that the for cam sensors they are all the same, the difference is the plate holding them, can i swap them to verify which is damaged???
thanks
Old Jul 9, 2010 | 03:52 PM
angel700's Avatar
angel700
273 views and no answer :s
Old Jul 14, 2010 | 12:12 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
If you have a bad cam position sensor your ECU should throw a code indicating which one is bad. What is the problem that you are having?
Obadabot
Jun 18, 2023 11:31 PM
