white smoke coming from engine bay
Old Jul 17, 2010 | 12:31 PM
Z You Later's Avatar
Z You Later
Default white smoke coming from engine bay
So as the title states, today when I was driving to work, everything seemed fine until I parked...a little bit of white smoke drifted up from under the hood. When I opened the hood I heard a hissing/steaming sound coming from the Inside of my intake?
To set up the story we had a BUNCH of rain and on the last day of all of it, my gauge cluster stopped working ie RPM and speedometer. The next day everything seemed to be working fine until today. The problem with the gauges started about 2 days ago. Any Idea? Engine mode that could have part is my JWT Popcharger, upgraded grounding wires...I have other engine mode but all would not have anything to do with this.
Old Jul 17, 2010 | 12:55 PM
BonesZ33's Avatar
BonesZ33
Old Jul 17, 2010 | 01:06 PM
Z You Later
^ go troll somewhere else and give me my 2 seconds of life back...
Old Jul 17, 2010 | 01:19 PM
BonesZ33's Avatar
BonesZ33
oh you want some real help do you? Well I work at a perfomance shop for my occupation so let me see if i can be of any assistance to you.
Smoke coming from inside the intake? and a hissing noise.. this doesn't help at all.. smoke was probably from the water hitting your hot engine
To
am obvious wiring problem,a bad ground.. find a fsm and look over all the grounds and check connector connections
what is a mode? take off the grounding wires and connect all the factory grounds. other than that sounds like your not going to be able to fix this yourself
Old Jul 17, 2010 | 04:29 PM
Z You Later
Predictive text on my phone is still learning, I meant mods not mode...the smoke dissipated before I found the location but the hissing/overheating sound was coming from inside the Intake.
Old Jul 17, 2010 | 05:30 PM
BonesZ33's Avatar
BonesZ33
is the car overheating? is water temperature normal?.. did this start to happen only after you installed the grounding kit?.. hissing from the intake could be a normal sound that you've just never heard before.. there isn't really a bad way to install a pop charger unless you left something inside the intake.. check for a vacume leak .. there is a vacume hose under the intake tube , did you leave it off?
your description of the problems only leads me to vauge speculations.. Although the tach issue is most likely a grounding problem, or a connection problem. start your search in areas that YOU'VE messed with recently.. start with the obvious first.. other than that Come back with more info.
Old Jul 17, 2010 | 06:56 PM
Z You Later
I'll put more details when I can get to a computer...the grounding kit and Popcharger have been on for a long time with no Issues. I've had zero Issues until the storms came through. I dont think water got in the engine since it runs fine but Ill double check the connections tomorrow morning.
Old Jul 18, 2010 | 02:35 PM
Z You Later
Found out the problem today, my A/C condensor burnt up FML
3vilbunny
Jul 18, 2017 05:10 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
