ABS/Slip/TCS lights all on
Old Jul 30, 2010 | 12:25 AM
corymm_88's Avatar
corymm_88
Default ABS/Slip/TCS lights all on
Hey, I have 2003 nissan 350z 5AT, here's the problem, my ABS/Slip/TCS lights are all on when I put my car into drive and move a couple of feet. When I took it to the dealer they said that my ABS pump is not pressurizing correctly and it would cost 1600 to fix. The other day I was driving and put my car into neutral and shut off the engine and turned it back on while I was moving and back into drive and my lights never came back on unless I put it into park. My traction control worked perfectly but I didn't try out the ABS yet. Anyone know if it truly is my ABS pump or is there something else going on? Thanks.
Old Jul 30, 2010 | 05:27 AM
huyrua's Avatar
huyrua
Take it to Autozone and get it scan. Search the code numbers that come up or post it here. You have to be more specific
Old Jul 30, 2010 | 09:30 AM
corymm_88's Avatar
corymm_88
It wasn't throwing a code, I took it to autozone and they said the dealer has to check the ABS. So I did that and all they told me was the pump is not pressurizing correctly.
Old Jul 30, 2010 | 10:01 AM
JSeide36's Avatar
JSeide36
id say it has something to do with the temp but seeing your in texas im prob wrong.. my car used to the the same thing when i was in NY and it was sub 40 degrees in temperature
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
