what the fork... my Z overheated ._.
Old Aug 16, 2010 | 07:26 PM
Mitsuomi's Avatar
Mitsuomi
Default what the fork... my Z overheated ._.
My Z overheated today -_- i was idle for about 10 minutes and smoke started coming from under the hood. It was random, never did it before and i'm not sure what could be causing the issue. The car only overheats when its idle, if the car is running the temperature stays normal.
I checked the Fans and they seemed to be working fine, now the only thing i can think of is... I had my car getting a paint job. I noticed that they didn't remove the front bumper to paint it, so the radiator is full of paint. Could that cause the car to overheat? If thats not it then i really don't know. I'll have to take the car to the dealership or some random mechanic tomorrow morning ._.
I will take pix of radiator tomorrow morning. At least they did a good job matching the radiator with the bumper though '_'
Old Aug 16, 2010 | 07:27 PM
SageZ's Avatar
SageZ
fork it
Old Aug 16, 2010 | 07:39 PM
xthejokerx's Avatar
xthejokerx
Originally Posted by SageZ
fork it
+1...
try forking it op...
Old Aug 16, 2010 | 07:47 PM
Mitsuomi's Avatar
Mitsuomi
Great idea. Why didn't i think of that? I will fork it tomorrow morning. Besides that, anyone have anything "helpful" they want to share? I am no expert so any advise would be greatly appreciated. If i knew exactly what the problem was i would't even be posting here.
My other concern is if the problem is in fact paint on the radiator, and the shop that painted the bumper refuses to take responsibility, is there any legal action i can take? I just want to be well informed so i know what to do/say when i take the car to the shop tomorrow.
c0ld29's Avatar
c0ld29
Are you f'n serious? Who the hell painted your car and didn't at least mask off the radiator? YES the paint will completely ruin the efficiency of your radiator. Thats why you shouldn't take spray paint and write out "JDM LOLZ!!" on your radiator.
Unless you use a thin (oil based I think) radiator paint, but since it is car enamel paint the heat transfer will suffer greatly.
Of course they are liable to replace your radiator, as long as you have proof they painted your car. Even in civil court it would be an open-shut case, no need for a lawyer.
Old Aug 16, 2010 | 07:58 PM
Mitsuomi's Avatar
Mitsuomi
I am not sure why they didn't mask it off... i didn't even notice the radiator was full of paint until today. I was checking the fans and the coolant fluid with my dad to see why the car was overheating and everything looked fine, until we noticed the radiator was full of silverstone paint. Shiny radiator ftw... I am not 100% sure this is whats causing the issue, but given that the car ran fine before, and that it only overheats when its idle, and that it started overheating AFTER the paint job, i thought that the paint could be the issue. I will take the car to the shop tomorrow, hopefully they either clean it (if possible?) or just replace it.
The worst part is that they took 3 weeks to paint it lol so i was carless for 3 weeks, and now this >_>
I hope they dont take 1-2 weeks to replace/clean the radiator :|
Old Aug 16, 2010 | 07:59 PM
billsrcursed's Avatar
billsrcursed
Seriously, just take the receipt for paint job back to the business, ask for a Manager, explain the situation, and allow for them to fix it.
You're jumping the gun at this point.
After they tell you to "fork off", then I'd speak w/ a lawyer....
EDIT - You're faster than me, lol!! See you already plan on doing this. It's the right first step.
Old Aug 16, 2010 | 08:03 PM
Ruthless18x's Avatar
Ruthless18x
Fork that ****.
Stock2Autocrozz's Avatar
Stock2Autocrozz
Radiator is F'D...would threaten with action from concilliation court (small Claims), limit for action is up to $7995 in MN, check your state, plus damages and repair and loss of car time total, may have a sweet little claim going...however, also turn them into the BBB (Better business bureau) That kills a company rep and requires investigation...they should handle your claims just fine then...best of luck
Old Aug 16, 2010 | 08:04 PM
c0ld29's Avatar
c0ld29
edit : nvm
Old Aug 16, 2010 | 08:13 PM
billsrcursed
That's ridiculous. He hasn't even talked to the shop about it yet.
People like you crack me up. Businesses make mistakes, too. Most of the time, if you approach them with some friggin class and dignity, they're more than willing to fix the mistakes.
Walking in there like you own the b!tch threatening everyone's jobs gets you nowhere fast, and probably knocked the "fork" out if we're all lucky enough.
Old Aug 16, 2010 | 08:17 PM
BoomerZ33's Avatar
BoomerZ33
what the forkkkkk! those guys owe you a new radiator
Old Aug 16, 2010 | 08:25 PM
Mitsuomi's Avatar
Mitsuomi
I see everybody is loving the "fork" huh?
Yes i haven't taken the car to the shop yet, and I am not the type of person that is looking for every single chance to sue people/companies. Looking at it from the owner's perspective, it isn't his fault, he runs the business but in the end it is the employee who made the mistake. As long as they take responsibility for their mistake and fix it, that's good enough for me.
I will post pictures tomorrow of the radiator and i'll let you know what the shop says!
Old Aug 16, 2010 | 08:29 PM
c0ld29's Avatar
c0ld29
I say you get a fork decal for your car now, its only fair for the rest of the forum
Old Aug 16, 2010 | 08:37 PM
Mitsuomi's Avatar
Mitsuomi
https://www6.hsmv.state.fl.us/mvchec...check/main.jsp
I've been thinking about getting a custom license plate. "Fork it" is not available but "Fork You" is! (This is in FL btw)
Old Aug 16, 2010 | 08:47 PM
winchman's Avatar
winchman
Wouldn't the paint be on the AC condenser coil, since it's in front of the radiator?
That's probably more expensive to replace, even though the cost of the part is less.
I'm thinking the "fork it" comment was about using a fork to remove the paint from between the fins. A radiator fin comb and some paint solvent would probably do that, but it ain't gonna be easy.
Old Aug 16, 2010 | 08:58 PM
xthejokerx's Avatar
xthejokerx
Someone's thinkin' outside the box
Old Aug 16, 2010 | 09:29 PM
Stock2Autocrozz
merely provided proper outlets for course of action
Old Aug 16, 2010 | 10:07 PM
neight's Avatar
neight
do you have photos of zeese?
Old Aug 16, 2010 | 11:01 PM
terrasmak's Avatar
Dammit, i was hoping i was going to be the first person with a clue in this thread.
