Jack point on Z with Nismo finned diff cover?
Old Aug 27, 2010 | 11:41 AM
2fasst's Avatar
2fasst
Default Jack point on Z with Nismo finned diff cover?
After some key search words I couldn't find any posts about where most people with Nismo finned diff covers jack their cars up from.
Is the finned Nismo diff cover strong enough?
Old Aug 27, 2010 | 12:00 PM
Ruthless18x's Avatar
Ruthless18x
Wouldn't put the jack on those fins. I just use the stock jack on the areas designated under the skirts. Then just put stands.
Old Aug 27, 2010 | 12:02 PM
2fasst's Avatar
2fasst
hey thanks for your reply, but i don't think those 'tabs' under the skirts are meant for a single floor jack/emergency-type jack either as they tend to bend easily.
hmm...
Old Aug 27, 2010 | 12:11 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Jack up from the radiator :P just kidding here you go:
Old Aug 27, 2010 | 12:14 PM
Ruthless18x
hmm...
They aren't meant for a floor jack, I've never had anything bend using the stock screw jack.
2fasst's Avatar
2fasst
thanks man...I can't jack from the rear diff cuz i have a finned Nismo cover. And i 'shouldn't' jack from the 'Safet stand point' because jack at one car is not spreading the weight evenly, putting too much weight on one corner and bending my tabs.
Old Aug 27, 2010 | 12:15 PM
BLACK-OUT's Avatar
BLACK-OUT
jack from the pinch rails.. i've done it numerous times. they are fine.
Old Aug 27, 2010 | 12:16 PM
BLACK-OUT's Avatar
BLACK-OUT
or jack from your rear pumpkin..
dikspiel's Avatar
dikspiel
Chestons Toilet
If you have the nismo finned diff then you have no choice but jack from the safety stand points. Thats what everyone does.
Old Aug 27, 2010 | 12:18 PM
Ruthless18x
OP doesn't seem to get the point.
ms6to350z's Avatar
ms6to350z
hmm...
hey not trying to start a war or anything here but if you're referring to the long rails that run along under the skirt, you can definitely jack the car there. i was taught that way and i've done it on all my cars. its mainly meant to be used for the wheels free lifts with the jack pads, but whatever you can get under should suffice.
Old Aug 27, 2010 | 03:09 PM
Wu-Watt's Avatar
Wu-Watt
I have a nismo diff cover and I've had the car on a jack using the differential for the jacking point. Put the jack just behind the fins.
Old Aug 27, 2010 | 03:30 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
I've always jacked it up from the front/center portion where the fins are located if I had the nismo diff cover. I dont know if I would be comfortable doing as Wu Watt suggested.
Old Aug 27, 2010 | 03:49 PM
diablox1's Avatar
diablox1
sounds like u know nothing about jacking up cars man. stock screw jacks that have a slot in the middle of the contact point (IE the 350z stock jack) are made specifically for jacking up by means of the "safety stand points" shown. the rails behind the sideskirts slide into the slot i mentioned, giving the jack a bit more latteral support. you will be fine. you're not putting ALL the weight on one corner, its distributed to that corner plus the jack. this is exactly how any modern car is designed to be jacked up, and exactly how the owners manual tells you to do it for flat tires, etc. dont be the ghey and teh sux and just do it.
Old Aug 27, 2010 | 06:23 PM
DavesZ#3's Avatar
DavesZ#3
Use a small piece of 2x4 and place it so the block of wood is under the body of the diff and up against the edge of the fins. That way there's no chance of putting weight on the fins themselves.
Old Aug 27, 2010 | 06:58 PM
JasonZ-YA's Avatar
JasonZ-YA
This is exactly what u need to do...you need to lift from the diff under belly with out contacting the fins.........when you lower the car, you also have to do so gradually because if you slam it down the suspension will compress and you can still hit the fins............
I have the nismo diff cover and used to do this.......i still one time while rushing managed to break one of the fins......
I then later designed a hidden hitch and then made a straight shaft -center jack point - so to lift the car rear up to where i can change both rear tires at the same time at drift events.
It serves as a hidden hitch and later can put this solid shaft in and use it as a jack point. You can see the nismo diff cover in the pics.
PIN STAY JACK POINT:
IF you have an oem exhaust, or an oem like exhaust you can easily remove the rear pin stay and have a local welder weld a shaft that hangs down to a point that cant be seen but you "KNOW" is there.
Rear pin stay is this part:
It's held in with two 17mm hex head bolts (shown) and two 19mm hex nuts at the subframe mounts on each end. you can remove it and take it to a shop to have a center lift point shaft welded on that hangs down out of sight due to the oem like exhaust can hiding it.
-J
Attached Thumbnails Jack point on Z with Nismo finned diff cover?-img_6913.jpg   Jack point on Z with Nismo finned diff cover?-img_6915.jpg   Jack point on Z with Nismo finned diff cover?-img_6917.jpg   Jack point on Z with Nismo finned diff cover?-350z018-1.jpg
Old Aug 27, 2010 | 07:07 PM
JasonZ-YA's Avatar
JasonZ-YA
You can also make a puck for your floor jack and use the FSM approved pinch weld lift point locations.
-J
Old Aug 27, 2010 | 07:08 PM
JasonZ-YA's Avatar
JasonZ-YA
The proper jack point locations - as you can see they have a saftey stand mount that has a groove in it:
-J
Old Sep 3, 2010 | 06:57 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Thumbs up
Seen this at drift events...I want one J!!
He is done with swapping wheels...while Im still working on one side.. Really cuts time in half LITERALLY..
Old Sep 3, 2010 | 01:24 PM
winchman's Avatar
winchman
"Every time the vehicle is lifted up, maintain the complete vehicle curb condition."
What does this mean? It's highlighted in post #18.
ablaine
Nov 29, 2016 10:13 AM
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
