leak in my tire? tpms light on...
I recently got the TPMS light on my dash a few days ago for the first time on my 08 enthusiast. Found out that my rear passenger tire had like 24 psi. Took it to the stealership they charged me $77 to reset the light and fill the tire to 35 psi. Next morning the light came on again and tire pressure was at 24 again, drove to work and back and saw that my rear passenger tire pressure was at 14 psi!!! Im guessing I need a new tire right? The stealership said they checked for nails and stuff. Guess they didnt check good enough smh
All my other tires are good though.
Stealerships are greedy and mostly worthless IMO. Yes it sounds like you have a tire that is history, discount tire resets the TPS when they change out the tires, nc. Good ruck fella
Why does the light have to be reset? A few months ago the light was on in my '08 because I picked up a nail in a tire. Had the tire repaired - no more light. What am I missing here?
nissan said they had to recalibrate the tpms and reset the light. But it came on again cuz my tire keeps leaking air.
I understand that your tire is leaking, but I think it's a BS story that you've got to take your Z to the dealer every time the light comes on. The manual doesn't mention any such requirement. What happens if you reinflate the tire to 36psi? Does the light go out after a few minutes of driving?
This is from my owner's manual:
The low tire pressure warning light does not
automatically turn off when the tire pressure
is adjusted. After the tire is inflated to the
recommended pressure, the vehicle must be
driven at speeds above 16 MPH (25 km/h) to
activate the TPMS and turn off the low tire
pressure warning light. Use a tire pressure
gauge to check the tire pressure.
Recalibrating the TPMS (if it was really needed at all) should have been covered under warranty. It sounds like you got ripped by the dealer.
I had low a tire pressure warning when the temperature dropped a lot, and the light went out soon after I brought the pressures up to spec.
Sometime simply re-seating the tire beads will cure a slow leak. I had a slow leak in one of the tires on my Silverado. When I got a nail puncture repaired, the tire guy took the tire completely off the rim, and reinstalled it. The slow leak was gone after that.
If the low fuel warning light comes on, are you going to bring the car back to them so then can fill it with gas and "reset" the light? Of course not.
I suggest reading your owners manual some and becoming familiar with some of the warning lights and their causes. Learn to refer to the owners manual next time a light comes on and you'll save yourself a few bucks.
While they may not have found a nail, leaks can occurs from the valve stem and bead. Take it to a tire shop to get that fixed - they're cheaper than the dealer.
The dealer took advantage of your lack of knowledge of how the system works. The low pressure warning light tells you that you need air in a tire, it doesn't indicate a problem with the system. By taking it to them, you gave them free rein to do some diagnostics and that's what they charged you for.
The dealer did something for $77 not sure what. If you have a good relationship with the dealer maybe he will fix it like supposed to do $77 dollars ago.
BTW all dealers are not thieves. Bob Bell Nissan fixed a flat for me. Charge? Zero.
Your vehicle has also been equipped with a
TPMS malfunction indicator to indicate when the
system is not operating properly. The TPMS
malfunction indicator is combined with the low
tire pressure telltale. When the system detects a
malfunction, the telltale will flash for approximately
one minute and then remain continuously
illuminated. This sequence will continue upon
subsequent vehicle start-ups as long as the
malfunction exists.
my light was solid, i think thats only if my tire pressure is low. If it blinks then it means the sensor is bad. Well i just came back from work and put air back in the rear tire, up to 35psi and the light went away. Im gonna check the pressure again tomorrow and see if it drops again. then im going to a tire repair shop
