sucking air noise coming from the bottom of the car
Old Oct 1, 2010 | 10:37 AM
cachinbombete's Avatar
cachinbombete
Default sucking air noise coming from the bottom of the car
so there is this anoying noise that when heard from the inside of the car sounds like a speaker having interference, but i had the chance to be under the car while the engine was running and i was able to track it down to where I suppose it's located the fuel pump, however it's all covered up and close to the fuel lines, it sounds like if a pump was sucking air every three or four seconds. Any idea that maybe causing the issue
Old Oct 1, 2010 | 10:48 AM
DavesZ#3's Avatar
DavesZ#3
My guess would be the vapor purge tank/system.
Old Oct 1, 2010 | 12:48 PM
Dr. Venture's Avatar
Dr. Venture
you lost me at the phrase " it's located the fuel pump". But the fuel pump is in your glove box behind the p/s seat. My guess would be a manifold vacuum leak or possibly an exhaust leak.
Vapor leaks you really do not hear that from inside the car much.
Old Oct 1, 2010 | 01:12 PM
DavesZ#3's Avatar
DavesZ#3
Guess again.
Old Oct 1, 2010 | 01:35 PM
Dr. Venture
Guess what again? Are you implying that on a Z the fuel pump is not right under the glove box behind the passenger seat? Perhaps in the 07 and above it may or may not be moved to behind the woofer, but still.
Old Oct 1, 2010 | 02:10 PM
DavesZ#3's Avatar
DavesZ#3
Fuel pump is in the gas tank. But let's not digress....
OP indicated that he was able to get under the car with it running. That's how he isolated to the area of the fuel pump.
Old Oct 1, 2010 | 02:57 PM
Dr. Venture
Oh i should have pointed out if no one already knew that the Fuel pump was located in the fuel tank, with the exception of it being accessed from inside the glove box for a removal and replacement, or just to check to see the "hissing" sound a tad closer and better perhaps.
my bad!
Perhaps he just hears the buzzing sound of a fuel pump starting to go bad if thats the case.
Old Oct 1, 2010 | 04:03 PM
WhiteNoiz's Avatar
WhiteNoiz
nevermind, I was excited about finding out the fuel pump was accessed through the glove...ha
Old Oct 2, 2010 | 04:14 AM
Dr. Venture
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
PureR3d
Sep 10, 2015 06:23 PM
Daniel_dh
Sep 7, 2015 12:56 PM
