P0340 - help!
Old Jan 10, 2014 | 06:47 PM
Jisidr's Avatar
Jisidr
[QUOTE=rippn
After some research I will be talking to the dealership to see if they will replace the sensors related to the po340 and the recall, don't know if this still applies after all these years but hopefully.
The other issue I'm having is getting to the camshaft position sensor on bank 1. It's physically impossible to reach from the top, I have a stillen supercharger, anyone with that s/c replace the bank 1 cp sensor? I'd like to know how you did it.
Thanks.[/QUOTE]
I am having the same problem with the po340 and I also have the stillen supercharger. Can you shed some light on how to replace the sensor. Thanks.
Old Jan 14, 2014 | 02:09 PM
zakmartin's Avatar
zakmartin
You might want to start by calling Stillen. They may be using a different sensor. Go with what they recommend.
Old Jan 16, 2014 | 02:37 PM
Itzcashew's Avatar
Itzcashew
Its behind the engine, you can reach both sensor from the passenger side. I replaced mine with OEM and the SES stopped coming back. For some reason my car ate up those auto shop parts like crazy. OEM pleased it.
Old Jan 21, 2014 | 05:21 PM
chriswagner92's Avatar
chriswagner92
I replaced my pass side sensor in a parking lot in like 30 minutes. Hardest part was getting the sensor out and disconnected from the harness. Don't pay anyone to do it
Old Mar 13, 2015 | 06:06 PM
350zeee's Avatar
350zeee
I would sure like to know what is causing this P0340 code issue. Here I am back replacing this same part... 4 years later!! Camshaft position sensor. Bank 1 on the passenger side rear. Driving along car lost power and cut off, Sat for 10-15 min on side the road. It barely started again. got me home. Took to Autozone, to read codes...Same stupid code that I had 4 years ago!!!!! (come on NIssan recall and fix this crap)
I let Pep boys fix it last time, Part under warranty - I think I can replace this myself!
Tired of paying the Nissan Stealer. Also got codes C1130 and U1000. I think that's because P0340 threw up the first issue.
Old Dec 14, 2022 | 12:51 PM
Alexandros's Avatar
Alexandros
Default Code P0340
Originally Posted by Itzcashew
I honestly did not know how this happened. I went into subway to grab a sandwich and came back out BAM! The car took forever to start up and when it did it showed the TCS/SLIP/SES light. I took it to Autozone and got the P0340 code. Now i've been reading and some people say to just unplug the camshaft positioning sensor and replugging it. I tried that but it did nothing. I'm considering taking it to Nissan to get the stealership treatment. Any word of advice is well appreciated!
I have gmthe same problem after putting a new camshaft sensor ; any advice for fhe problem ;
leafjerky
19
Jul 23, 2024 06:06 PM
blazin202
Jun 25, 2014 04:09 PM
YardieXplorer
Mar 20, 2014 08:28 PM
Raginraj11
Nov 4, 2012 04:23 PM
