Almost blew my engine...Help!
Old Dec 8, 2010 | 12:35 PM
cityslick43's Avatar
cityslick43
Default Almost blew my engine...Help!
HELP!
My c/h gauge is acting up. I drive for 5 min and my car is to the highest level of "hot", I put coolent in and a week later same thing.. I cant drive my car because im scares to fry the engine i can drive maybe 2 miles until it overheats.. idea???
fluid flush??
Old Dec 8, 2010 | 12:41 PM
dcastillo819's Avatar
dcastillo819
thermostat could be sticking closed and not letting the coolant flow through the system. start the car and let it warm up feel the coolant hoses if the one with the thermostat is way cooler than the other one then its sticking closed. you will need a new thermostat. make sure that you get all the air bubbles out of the system when you fill the coolant system back up or it will overheat.
Old Dec 8, 2010 | 12:51 PM
SA Z-boi's Avatar
SA Z-boi
definetly your thermostat. Easy fix and the part is cheap at nissan
Old Dec 8, 2010 | 12:54 PM
POWUH's Avatar
POWUH
sounds like an air bubble to me , flush the radiator there's a few diy theads here and refill. I had a similiar problem I had to flush a couple of times though.
Old Dec 8, 2010 | 01:17 PM
bmccann101's Avatar
bmccann101
Default also..
turn on car. turn on a/c compressor.
if your fans dont start, its your fans. Could be any of the above, but this should be checked as well.
Old Dec 8, 2010 | 01:28 PM
porschett's Avatar
porschett
Default Fans?
Agree, check your fans operation. Don't know what year you have, but Nissan recalled and extended the warrenty. I just had mine replaced in Sept..
Old Dec 8, 2010 | 01:48 PM
If you are a DIY guy, and a gambler, replace the thermostat.
Old Dec 8, 2010 | 01:59 PM
zerosec's Avatar
zerosec
could be a leak in the cooling system make sure all the coolant hoses are fine.
also u need to double check the radiator fans, radiator cap, thermostat...
Old Dec 8, 2010 | 03:23 PM
cityslick43
thanks everyone, fans are running its the thermostat just need to find out how to replace it.. and how to make sure no air bubbles are there
Old Dec 8, 2010 | 08:51 PM
dirtbikr's Avatar
dirtbikr
I really enjoy this...
http://www.amazon.com/Lisle-24610-Sp.../dp/B001A4EAV0
Old Dec 10, 2010 | 08:59 AM
scotts300's Avatar
scotts300
Sounds like an easy fix at a trusted mechanic to me.
FromGtoZ
Sep 20, 2015 03:41 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
12SecZ
Dec 28, 2003 02:27 PM
teh215
Sep 29, 2003 06:43 PM
