Transmission Grinding
Old Feb 20, 2012 | 07:23 PM
  #61
sleeper400's Avatar
sleeper400
update?
Old Apr 25, 2012 | 10:47 PM
  #62
paulmess7's Avatar
paulmess7
I too am having this issue, what did you guys do about it?
Grinds / is hard to shift every gear above 3k rpms, shifts alright below 3k.
If I let the rpms drop a bit and shift very slowly above 3k there are no noises.
Changing my tranny fluid out, I already ordered it so I might as well. After I think I'll bleed the clutch.
I feel like the clutch isn't releasing all the way, going to try jacking up the rear of the car, put it in first with the clutch in, and see if the wheels spin.
My pilot bearing has been making noise for months, and still is. Might be related, might not.
Did anybody resolve this issue yet?
Old Apr 26, 2012 | 05:59 AM
  #63
djamps's Avatar
djamps
Originally Posted by eztax
Hmm, well my grinding has gone away.... I didn't do anything at all but just drive it.
I'm confused...
Could have been air in the clutch line. Eventually air works its way out with normal driving.
Old Apr 26, 2012 | 08:54 PM
  #64
paulmess7's Avatar
paulmess7
I think you're right. Mine has gotten better too.
Can anybody point me to a beginner's DIY guide to bleeding clutch lines? Everyone talks about how hard it is, but I haven't seen anything with pictures/tips.
Old Apr 30, 2012 | 07:44 AM
  #65
sleeper400's Avatar
sleeper400
i bled my clutch line and still have the same issue. This weekend I will be swapping out the motul mt90 thats in the trans now for some factory nissan fluid and see if that helps. I am noticing its getting harder to get into gears now too especially reverse then when I go back into first. I adjusted the shifter plate...
Old Apr 30, 2012 | 09:12 AM
  #66
F2CMaDMaXX's Avatar
F2CMaDMaXX
Sounds like slave/master and/or air in the line. I noticed delay in clutch disengagement (very very slight) as if the slave cylinder was catching up.
I bled the line through with ATE Super blue, very easy with a friend to pump the pedal as per the FSM instructions and now the clutch feels great
Old Apr 30, 2012 | 08:34 PM
  #67
eztax's Avatar
eztax
I have been driving around with the same problem for over a year. I still havent figured it out. I'm pretty close to replacing my whole tranny.
I replaced the pilot bearing when i changed my clutch ( i also had a broken piece that holds the pilot bearing lever)
Let me know if anyone figures it out... I hate driving my car this way...
  #68
eztax's Avatar
eztax
f2c, did your problem go away?
Old Apr 30, 2012 | 08:43 PM
  #69
F2CMaDMaXX's Avatar
F2CMaDMaXX
I never had the grinding problem as you guys are describing, but i notice the clutch feels like it's disengaging a lot cleaner now.
Old May 5, 2012 | 07:12 PM
  #70
paulmess7's Avatar
paulmess7
Update:
Took it to a transmission shop and my issue is indeed the pilot bearing. Trans fluid, bleeding clutch didn't help.
Old May 5, 2012 | 11:33 PM
  #71
F2CMaDMaXX's Avatar
F2CMaDMaXX
Nice, at least it's been found now, i'm assuming they completed the job and all is well now?
Old May 6, 2012 | 05:13 AM
  #72
paulmess7's Avatar
paulmess7
I wish... it's still very drivable, as long as I take it easy. So I'm going to shop around for a clutch kit/flywheel, and then I'll bring it in.
Old Jun 26, 2012 | 06:25 PM
  #73
sleeper400's Avatar
sleeper400
So I bled the clutch line (never had air in it) and it still had the problems. Today I replaced the redline mt90 trans fluid with OeM Nissan and its sooooo much smoother but it still grinds above 3k shifts. I noticed my rev match down shifts above 3k rpm don't grind anymore. I only put on 20 miles or so and I will give it more time but if nothing changes I will be taking the trans off and replacing the pilot bushing and observe the rest of my drive train components since it will be all exposed. 2 of my local mechanic Friends know what I have done/ replaced and they both seem to think there is something internally wrong with my trans =\ the vids the OP posted sound EXACTLY like my car and his shifting patterns of shifting above 3k results in a grind is identical to my problem.
Old Feb 13, 2013 | 04:20 PM
  #74
sleeper400's Avatar
sleeper400
Just a bump and a heads up... My issue a few months back literally went away by itself. I couldn't stand not being able to rip on the car so I banged 1- top of 5th on a nice road in Mexico and ever since that run.... Trans is as smooth as butter! I kid you not! I'm not responsible if anyone else tries this and something goes wrong but it worked for me!
Old Feb 13, 2013 | 05:32 PM
  #75
F2CMaDMaXX's Avatar
F2CMaDMaXX
What exactly does, "banged 1- top of 5th" mean?
Old Feb 14, 2013 | 03:31 AM
  #76
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Slammed 1st thru 5th
Old May 18, 2018 | 07:34 PM
  #77
Gabriel Lopez's Avatar
Gabriel Lopez
Has anybody solved their problem yet? I’m having the exact same issu
Old Sep 25, 2021 | 01:32 PM
  #78
keough's Avatar
keough
Have you solved the problem yet? I’ve bled the lines, checked linkage my next step is dropping the tranny
Old Nov 4, 2021 | 11:37 PM
  #79
Abraham preza's Avatar
Abraham preza
Any updates? This recently just started happening to my g35 as well
Old Nov 4, 2021 | 11:52 PM
  #80
keough's Avatar
keough
Ive done everything that all of these guys have done besides throw out or pilot bearing. My guess is that when I got a new engine the pilot part that’s on the engine was damaged while being removed from the original transmission. I’ll let y’all know when I get it done it should be in like a month or so.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
