Help with 04 Touring Window
Old Jan 17, 2011 | 08:17 PM
Get_In_Z_Plane!'s Avatar
Get_In_Z_Plane!
Default Help with 04 Touring Window
Hey guys. I recently bought an 04 Touring and the drivers side window's auto-up doesn't work. It will go down with one push but if I try and do the auto-up (not sure technical term here) the window will go completely up then will go down again about a 1/3 of the way? Ideas?
Old Jan 17, 2011 | 08:20 PM
Get_In_Z_Plane!
It even does this when I put the windows up using the key. They will both go up perfectly fine, but the drivers side once closed will then drop back down.
Old Jan 17, 2011 | 09:16 PM
terrasmak's Avatar
Window motor is on it way out
Old Jan 17, 2011 | 09:17 PM
dirtbikr's Avatar
dirtbikr
The motor needs to have the re-learn procedure done most likely. My 07 did the same thing and it wouldn't re-learn, so it had to be replaced. Download the FSM for your car if you want to attempt the re-learn procedure yourself. It's kind of a pain, but if it works you'll be golden.
Old Jan 18, 2011 | 05:57 AM
DaveJackson's Avatar
DaveJackson
Master
Someone asked the same question about 17hrs earlier but here is what that guy was told:
https://my350z.com/forum/5655852-post2.html
I think this is what dirtbikr was talking about.
Old Jan 18, 2011 | 07:47 AM
PerfZ's Avatar
PerfZ
Wrong.
Old Jan 18, 2011 | 11:10 AM
terrasmak's Avatar
Originally Posted by PerfZ
Wrong.
Every time mine has done that, within a month the window motor failed.
Old Jan 18, 2011 | 06:04 PM
PerfZ's Avatar
PerfZ
My passenger side did it and the dealer reset it while the car was in for some recall service 4 years ago. Started doing it again about 2, maybe 3 years ago. I just coax it up instead of using auto-up until I happen to have the door panel removed to get to the reset button.
(Who was the idiot engineer who put the reset button in a totally inaccessible place?)
A failing motor generally results in the window not going all the way up or down - not in backing down on auto-up where the sensor just thinks it is running into an obstruction.
Old Jan 19, 2011 | 03:21 PM
fastturbinejets's Avatar
fastturbinejets
Default window motor
Auto zone has a remanufactured for $100.00 with a lifetime warranty. Ive done three.......woooo hoo!
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
Siqcology
Sep 18, 2019 01:45 PM
Jambo016
Sep 16, 2016 01:08 PM
