2nd gear grinding and transmission replacement
Old Nov 24, 2003 | 09:48 PM
rands's Avatar
rands
Default 2nd gear grinding and transmission replacement
i've been getting alot of grinding lately from second gear. using the forum search, i see that alot of you are experiencing the same thing ('04, 1900 miles). i'm also seeing many posts of people not happy with their replacement transmissions, and some mentions of a new clevis pin that supposedly fixes the problem. so, here's a couple of questions for you:
1) those of you with transmission replacements, would you say the transmission is 100% now? is it better or worse?
2) anyone had only a clevis pin replacement and had the problem fixed?
3) how long does a transmission replacement usually take?
thanks
Old Nov 24, 2003 | 11:14 PM
ssk0771's Avatar
ssk0771
Default Re: 2nd gear grinding and transmission replacement
thanks
None of the above will fix your tranny problem. I had 2 tranny replaced & 3 clevis pin replace and I am still having same issue.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
