help!! car stuck in limp mode tcs slip light on
Old Mar 6, 2011 | 08:56 PM
e=awesome's Avatar
e=awesome
Default help!! car stuck in limp mode tcs slip light on
2003 350z 49k miles but was hit in the front at one time...
the car goes into limp mode after driving check engine light and TCS and SLIP lights come on but if car sit can be reset and driven again til samething happens ...
replaced ecu
throttle body
pedal sensor
codes are
po507-speed control
po550-steering pressure sensor circuit
p1229-sensor power circuit
p2122- accel pedal pos sensor 1 circuit
p2138- accel pedal pos sensor
any ideas ? bad ground or bad wire is all i can think
Old Mar 7, 2011 | 02:57 AM
DavesZ#3's Avatar
DavesZ#3
Crank or cam position sensor.
Old Mar 8, 2011 | 12:05 PM
dragonfire6's Avatar
dragonfire6
Default ...
I dealt with this problem but my car was never hit... The culprit was a bad connection at the wiring harness in the passenger footwell... I used dielectric grease and tiny strips of aluminum foil to make sure the pins were making a connection and haven't had a problem since
Old Mar 13, 2011 | 12:13 PM
xchriz012x's Avatar
xchriz012x
can you be more specific?
i am trying to avoid going to the dealer's. they r known to rip people off!
thank you.
Old Mar 13, 2011 | 03:33 PM
dragonfire6
Default ...
I would start with MAF sensor cleaner on all connections... Throttle body, gas pedal and ecu and if the problem continues try to look for bent pins at each connection point... I pinpointed my problem pins from the codes that the car was throwing and was able to beef up each by adding slivers of aluminum foil to those specific pins...
Old Mar 13, 2011 | 08:41 PM
anedelen's Avatar
anedelen
Idk what your problem is but I'm currently dealing w the exact same problem!! Let me know if you figure it out and I'll dk the same!
Old Feb 14, 2012 | 09:26 AM
T41089's Avatar
T41089
Just got mine back today. Pulled a p2135 (Throttle Position Sensor) with an OBDII reader. Got the throttle body replaced and she is running better than she was before. Cost me $484.
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
Vigman
Nov 17, 2015 04:34 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
ddegrande21
Sep 6, 2015 11:15 AM
