RPM jumping wildly
Old Apr 3, 2011 | 07:34 AM
Sunjian's Avatar
Sunjian
Default RPM jumping wildly
Hi, I just bought a 2007 Nissan 350z Manual Transmission VQ35HR. Whenever I started my car in the morning I waited for 5-10 minutes before driving it(to warm up the car) After this, I drove it out normally with first gear RPM around 1500-2500 but what happened was the RPM needle jumped up and down wildly around those RPM(1500-3000), then I pulled over and tried to drive it again and it happened again and after the third time trying it again, there was no problem to it anymore. When this happened, I would pull over immediately and try slowly revving it up again a few times, then it is gone. Usually this happened only in the morning or when the car is still cold. I think 5-10 minutes of warming up a car is enough, please correct me if I am wrong.
This doesnt really bother me because this only happened when i started the car in the morning. But I am afraid in the long run it would affect the car very badly so before anything goes wrong, I am looking for a solution from the seniors here.
Thanks.
Old Apr 3, 2011 | 08:30 AM
R350Zz33's Avatar
R350Zz33
Thanks.
good thing theres only a 32 page sticky on this in the vq35hr section search https://my350z.com/forum/vq35hr/3078...g-warm-up.html
Old Apr 3, 2011 | 08:31 AM
winchman's Avatar
winchman
You're wasting gas and possibly damaging the engine by the excessive warm-up routine. The owner's manual says to wait 30 seconds, then drive the car at moderate speeds.
It's best to avoid excessive engine speeds and heavy throttle application until the car is fully warmed up. That usually takes several miles depending on the weather, etc.
Old Apr 3, 2011 | 08:48 AM
Sunjian's Avatar
Sunjian
Thanks for the link but I still havent found the solutions so I posted another thread, Should I just stick to the original 32 pages thread? If i have to, then please close this thread. Sorry.
Old Apr 3, 2011 | 09:19 AM
Welcome. I do not warm a cold motor before driving off, but it should not matter. The bouncing RPM may be the result of several problems including:
1. MAF sensor. Clean it.
2. ECU. Try a reset.
Old Apr 3, 2011 | 09:50 AM
amr_electron's Avatar
amr_electron
Same situation here & it doesn't matter if it's cold start or not. Even after new MAF, new TB, ECU reset several times, Still no luck.
I don't know exactly what causes it , I'm planning on getting a tune soon, Will see if it helps.
Old Apr 3, 2011 | 10:06 AM
midz350's Avatar
midz350
Is it just the needle bouncing? or the engine actual rpm also hesitate?
Old Apr 3, 2011 | 10:57 AM
amr_electron
This, As if the car is accelerating by itself.
Old Apr 3, 2011 | 11:16 AM
Sunjian's Avatar
Sunjian
The Actual Engine is also bouncing up and down. I do not know if the sputtering thread is the same issue as this. This happens when I am driving in the morning after the 5-10 minutes warm up. But this only happens for 1 minute.Then it disappears
Old Apr 3, 2011 | 11:28 AM
Sunjian's Avatar
Sunjian
Do you know if this problem is the same as the sputtering stickied thread? I saw the stickied sputtering thread and there are videos showing it sputter at idle but mine happens when I drive it after 5-10 minutes warm up. I havent tried it at idle though. The RPM jumps up and down so wildly around 1500-3000rpm i have to pull over.
Anyway this is the link to stickied sputtering thread
Old Apr 3, 2011 | 05:30 PM
amr_electron
No, It's totally a different issue, Sputtering happens for me always after a cold start. Some people reported that it's related to the oil, I tried different oil velocity with no luck. I always use premium gas but it's still happening .
Old Apr 3, 2011 | 09:37 PM
Sunjian's Avatar
Sunjian
So are you saying my problem is different from the link above? Have you read all the 32 pages? It seems that it is the same but from the video they are doing it on idle, but mine is when I am driving it.
Old Apr 4, 2011 | 07:11 AM
amr_electron
My car sputters only one time after every cold start, But the RPM will jump ( I can say that the car shudders ) every time i start moving the car from a dead stop while applying light throttle .
Old Jun 21, 2012 | 05:37 AM
Fulton16's Avatar
Fulton16
Anyone find a fix for this, I have the same issue
Old Jun 21, 2012 | 08:52 AM
zakmartin's Avatar
zakmartin
If you want suggestions for a fix, then provide the year of your car, the mileage, any engine modifications you've performed, your maintenance schedule (do you follow one?) and the conditions under which the issue manifests itself. The thread above does not necessarily apply to your car in an apples to apples comparison.
Old Sep 8, 2015 | 02:27 PM
Alex 350Z Fairl's Avatar
Alex 350Z Fairl
Default About Idle or Rpm misfire Resolved!!
Hey guys i got 05 nissan 350Z which i had to just a couple of weeks bought it not too long ago. I was having problems with the Rpm's being dumb. It would feel like it had a misfire when i had already replaced the coils, MAF and also the sparkplugs brand new from dealer but here is were the problem was after replacing all these parts i never disconnected the battery and never did the re learn process to the car so after i disconnected the battery and did the relearn procedure everything got back to normal here is a link to the steps you have to do, but be careful because it has to be done correctly http://www.technosquareinc.com/350reset.htm. Hope this helps alot of people having problems with misfires out there. So everytime you disconnect the throttle body plug of battery you have to redo the relearning process
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
Justin100
Nov 29, 2015 03:58 PM
Calinismo350z
Sep 14, 2015 04:04 PM
