Ligth heeelpp please!!!!!
Old Apr 5, 2011 | 03:05 PM
Zed1916's Avatar
Zed1916
Default Ligth heeelpp please!!!!!
Does anyone one what's wrong with my HID lights?? As you're facing the hood my right light doesn't work. I bought new ballast and bulb but nothing works. I tried everything on the other side and it works but when I put on the bad side nothing works. I checked the fuses evrything is fine, I checked the connections everything is fine too. So I don't know what it could be???? Any help is highly appreciated THANK YOU GUYS.
Old Apr 5, 2011 | 05:15 PM
chicagokid's Avatar
chicagokid
This might help. Did u check both fuse boxes next to battery? The one that's hidden off to the side (has black cover on it that lifts up)has a bunch if fuses for lighting. Check those fuses that relates to HID.
Old Apr 5, 2011 | 05:16 PM
gregom's Avatar
gregom
Can you try the left headlamp on the right side wiring? Sounds like you've confirmed the ballasts and bulbs are fine. Fuses are fine... could be a wiring issue or grounding issue. Inspect the wiring harness up as far as you can.
Did you get the grounding connection from the ballast igniter? If that isn't grounded the ballast wont power on.
cleanddong
May 1, 2020 04:12 AM
Musix4Dlife
Jul 24, 2013 11:46 AM
yellowspecv
North West
Jun 22, 2012 11:15 PM
abc
Jan 19, 2007 08:24 AM
