Car won't start/no code :(
Old May 13, 2011 | 06:35 PM
iheartmyz's Avatar
iheartmyz
Default Car won't start/no code :(
Hey everyone, quick background info: I drift, last time I went, cooling fan wire got ripped up a little. Yesterday I'm driving to my friends house and the front of my car ate up some road debris, nothing big and everything seemed fine so I kept going because i was about 20 minutes away fron my friends house. I kept a close eye on gauges and sensors. After about
10 minutes of issue free driving, temp goes up, car starts clunking, then dies. I pull off the road to find the center of my bumper missing, radiator leaking from the drain plug on the bottom. I let the car cool down till my friend arrives with his trailer, start my car, drive it up and he brings it to his house. We drive it in to his garage and start working. The drain plug was stripped so we replace the radiator with a spare he had, fix up the fan wires, fill back up with coolant and go to start it back up. Battery is dead. I've never had an issue with my car needing to be jumped before. Once we jump it, it sounds like it's misfiring, bad. Turn it off and start looking at possible issues. We can't find anything and now the car won't even start??? Could we have grounded a wire somehow while replacing the radiator?? If so, why would that cause the car to misfire?? There are no codes and we don't know what's up other than possibly the fan wires. Anyone have a clue or any suggestions?? Thank you in advance!
Old May 13, 2011 | 07:09 PM
midz350's Avatar
midz350
Do you hear the fuel pump humming when the key in ignition turn to the ACC?
If not, then its your fuel pump. (happened to me once because of a dead battery)
Old May 13, 2011 | 09:47 PM
iheartmyz's Avatar
iheartmyz
Fuel pump is good. Tomorrow we're gunna re wire the fans to be on a switch of some sort and just run new wire to bypass any potential shorts. Any other ideas?
Old May 14, 2011 | 06:46 PM
bottlefedZ's Avatar
bottlefedZ
Have you checked your fuses?Check the one on the positive battery cable...GL
Old May 15, 2011 | 08:13 PM
iheartmyz's Avatar
iheartmyz
All fuses checked out alright...charged the battery for a few hours while I carbons fiber wrapped my roof (pimp) and it started up. It was rough. It would go back and forth from misfiring to running fine till the white smoke came...it started smoking out the exhaust BAD. It threw 6 codes, well 3 codes twice. P0335, p0340, p0345 if i remember correctly. Checked the oil, it was milky...looks like I gotta change the head gasket I still don't know how this would explain the battery dying...gotta get the parts and do the work and see where I'm at...any ideas are still welcome!
Old May 15, 2011 | 09:13 PM
Duckeee's Avatar
Duckeee
from your description, it seems like you knew the temp gauge was starting to creep up so you pulled over before it overheated..? if so your headgasket should be okay, but milky oil says no lie.
have your checked for possible vacuum leaks and leaky hoses?
Old May 15, 2011 | 09:24 PM
iheartmyz's Avatar
iheartmyz
Since I pulled off the road, the car has ran for a total of like 2 minutes. I've been scrambling looking for coolant leaks, checking codes and there was a bit of just sitting there in awe listening to how bad it sounds...its holding fluid pretty well for a car with blown head gaskets...just a lot of white smoke and milky oil so once I rip that all apart, I'll see if that just fixes it...hopefully. I'll check for vacum leaks next weekend when I start working on it again...
Old May 17, 2011 | 05:16 PM
iheartmyz's Avatar
iheartmyz
anyone think i need to have my heads looked at?? i dont think they'd be warped, i the temp was up on the car for all of 20 seconds....unless the temp sensor was bad...
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
lolwatbro
Oct 9, 2021 04:58 AM
350Z Project X
Oct 17, 2015 05:16 PM
RyansZ33
Sep 15, 2015 05:54 AM
