Severe Oil burning! 04 6mt G coupe
Since your car is running good and you are looking for a cheap solution....................just keep adding oil as it burns down. Oil is about $4.00 per quart and if you are only burning a quart every thousand miles or so, your annual cost for the additional oil will be about $50. Save your money and rebuild it the right way when you have the funds.
a quart every thousand miles is not revealed through the exhaust typically - if his car is smoking to the point that it's Spy Hunter time, the engine is done and needs a rebuilt stat
