Changing 350z automatic transmission fluid brand!!
Old May 22, 2011 | 12:10 AM
dbrown's Avatar
dbrown
Default Changing 350z automatic transmission fluid brand!!
I notice that no one has ever changed there automatic transmission fluid to an other brand other then Nissan. The manual says matic "J". But my dealer told me J is now "S". What I want to know is can I use a simple brand like Valoline or royal purple instead of Nissan OEM? Just as ling as it is for my transmission.
Old May 22, 2011 | 01:42 AM
johndoesdamage's Avatar
johndoesdamage
i used redline and its been working fine for about 1 year now
Old May 22, 2011 | 03:02 AM
winchman's Avatar
winchman
Dang, two people actually admitting they have automatics. There's hope after all.
Old May 22, 2011 | 06:29 AM
dbrown's Avatar
dbrown
I think I want to use royal purple.
Old May 22, 2011 | 06:36 AM
silvertouringz's Avatar
silvertouringz
changed mine with the expensive matic j and the shifts r smoother and faster
Old May 22, 2011 | 07:01 AM
Nissan engineers don't know what the hell they are talking about. Pickup a couple of cans of transmission fluid from WalMart.
Old May 22, 2011 | 08:20 AM
omsin523's Avatar
omsin523
J matic fluid has been discontinued from nissan, its called s-matic fluid now
Old May 22, 2011 | 08:51 AM
zheiland's Avatar
zheiland
Default The Best
The best you can buy is Amsoil
syn.auto tran fluid.It has a very
low and extreme high temperature rating.They use it in replacement for hydraulic fluid
on the drilling rigs up here.I use
it in two other heavy duty vehicles
I own.I use it in my lift in my garage.I have been using it
as power steering fluid in the Z
for over two years with no problems.
Old May 22, 2011 | 11:02 AM
vlado_t's Avatar
vlado_t
They don't. If they knew they would have designed the 6 speed MT right in this cars on first place, still don't have it right after 9 tries. The front suspension as well (my '08 has serious cupping problem).
Anyway, they want you to buy their product so they say using other than Nisssan matic J or S will decrease it's performance and/or damage the trans. Amsoil, Redline, even Castrol Multi vehicle is matic J compatable, so will work just fine. I know 3ppl that use this fluids in Titans, Exterras for years without any issues. I have AT and will likely use Matic S, not because it is special, but because it's price is competable with the ones I mentioned, and there is a dealership down the street from me.
Also, I've seen vergin fluid analysis of the matic S, and there isn't anything special in it.
good luck
Old May 22, 2011 | 11:21 AM
ImWeeZzel's Avatar
ImWeeZzel
this:
Its like 10+ a quart but some members claim they can buy it cheaper on ebay
Old May 22, 2011 | 07:15 PM
dbrown's Avatar
dbrown
I changed it with Valvoline ATF shifts fine (at least today it did) the new ATF works for j,s,d so i figured it should word for my car too..
Old May 23, 2011 | 08:14 AM
e46330i's Avatar
e46330i
Originally Posted by ImWeeZzel
this:
Nissan part number 999MP-MTS00P Cost is $6.79 - List is $12.31
Old Sep 21, 2013 | 11:08 AM
micho196's Avatar
micho196
Default 350Z ATF replacement
Hi All,
Last week I tried to change my automatic transmission fluid in my 2004 350Z. Car has 78K miles mileage and I think that ATF has been never changed before. When I was buing my car previous owner wasnt be able to tell me if the ATF been ever changed. I bought 12qt Nissan Matic S from USA (I'm from Poland). I tried dynamic replacement described in Service Manual.
OK I did it, poured same volume which was drained with checking fluid level on bayonet. Everythink looks ok, transmission is changing gears smoothly but after test drive I feel that car is less "agressive" to pressing acceleration pedal. Is it possible?
Is it possible to spoil something during replacement? Or it's only my strange feeling?
Old Sep 21, 2013 | 06:48 PM
ImWeeZzel's Avatar
ImWeeZzel
Drive it for a few miles and check the dipstick again. Best thing to do is measure the amount of fluid drained vs the amount of fluid you replace it with. That will also help determine if you're burning fluid. Most likely you need to add fluid.
Hope that helps.
-WeeZzy
Old Sep 21, 2013 | 09:00 PM
terrasmak's Avatar
I've put amsoil ATF in a few customers cars, no problems at all.
Old Sep 22, 2013 | 12:37 AM
micho196's Avatar
micho196
Hope that helps.
-WeeZzy
I understand that should warm up transmission and then check fluid level on HOT range of dipstick? I checked it on COLD range and its ok. I also thought to add more fluid but during replacement I measured amount of drained and replaced fluid...its the same. What will happen when I overfill fluid?
I dont understand how can I determine if I'm burning fluid by checking amount...
Old Jun 30, 2018 | 11:47 PM
RoysmancaveI's Avatar
RoysmancaveI
Default T fluid
Autozone sells Castol Import compatible full synthetic $5 a quart
A_MEISTER
Suspension
Oct 25, 2015 04:50 PM
3vilbunny
Sep 13, 2015 12:31 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
