Help! Z Wont turn on with a turn of Key???
Old May 23, 2011 | 06:31 PM
caferna3's Avatar
caferna3
Default Help! Z Wont turn on with a turn of Key???
What do i do? my 04 touring 6spd w 60k takes at least 3-7 turns of the key and pushing down on the clutch to start up.... then runs like a champ??? anybody have this problem & how to fix.?
Old May 23, 2011 | 08:50 PM
skakemokid's Avatar
skakemokid
Clean your clutch switch, its prob dirty
Old May 23, 2011 | 08:52 PM
MadNismo's Avatar
MadNismo
test ur battery?
Old May 23, 2011 | 10:09 PM
winchman's Avatar
winchman
Clutch switch might be improperly adjusted.
Old May 24, 2011 | 07:10 PM
Chefscott360's Avatar
Chefscott360
Default cluch switch ?!?!
guess thats why I have to have my clutch ped. all the way to the floor ??? can be adjusted foward some ?
Old May 24, 2011 | 10:46 PM
winchman's Avatar
winchman
There are two switch on the clutch pedal assembly under the dash. The one you need to adjust is on the forward side, and it's called the clutch interlock switch. Section CL of the service manual has all the details for adjusting it.
You should be able to reach the switch. Put the car in neutral with the parking brake securely on. Operate the switch by hand while trying to start the car. If that works, the switch is OK, but needs adjustment. If that doesn't work, the switch needs to be replaced, and new one needs to be properly adjusted during the installation.
Old May 25, 2011 | 08:40 AM
Spider Monkey's Avatar
Spider Monkey
Old May 25, 2011 | 12:46 PM
caferna3's Avatar
caferna3
Default Starts up perfect now>>>
Found the problem, my clutch needs some adjustment because it dosent fully depress the Clutch Sensor... I press w my foot and Z turns over strong w no problem... thanks "Winchman " Now i got to figure out how to adjust the pedal height...?
loudtoyz
Apr 6, 2023 04:52 AM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
