Water Pump Question
Old May 29, 2011 | 09:39 PM
lbz's Avatar
lbz
Default Water Pump Question
Does anyone know or has heard when the water pump should be replaced or starts to wear out?
I'm considering doing it as a preventive maintenance as my Z recently went past the 100K miles mark (end of ext warranty) but if I've still got a decent interval of time left, I'll hold off.
No symptoms at all, just wondering.
Thanks
Old May 29, 2011 | 10:29 PM
rneoaz's Avatar
rneoaz
Haven't had no issues with mine. I'm at 114000 miles and still looks good!!
Old May 30, 2011 | 04:36 AM
winchman's Avatar
winchman
The water pump on the VQ engine is inside the front timing case and driven by the timing chain. You don't want to go there unless it's absolutely necessary.
Old May 30, 2011 | 12:03 PM
lbz's Avatar
lbz
^ Yep. I understand that. Just wondering if anyone has any information about when the typical replacement time is.
Old May 30, 2011 | 01:39 PM
0jiggy0's Avatar
0jiggy0
It doesn't have a technical wearout time. No car does. Unfortunatly there's no reason you'd ever be there like a timing belt car. I've done 2 on a 95-99 maxima (vq30de). Its not that bad. But it is on the chain, which means no amateurs.
350z82
Oct 1, 2015 06:25 PM
