Clutch issue
Old Jun 16, 2011 | 04:09 PM
Dblock55's Avatar
Dblock55
Default Clutch issue
Hey all, been having this clutch problem recently but havent had much time to fix, now i have some time, but am not sure what exactly needs fixing.... it started with the clutch squeeling when depressed (definitely throw out bearing, have had this before) but then that went away and now theres a slight whine the clutch isnt depressed, sounds like a bearing, but goes away when clutch is depressed which is weird because throw out bearing is spinning when clutch is depressed..... the whine starts only after the car is driven for a while, not initially, also the clutch pedal has been sticking really bad, have bled it several times and still does it, again only after a few miles will it start sticking.... if it stick, i can rev the engine high in gear and itll be firm for a shift or two, but will go back to sticking...... its the throw out bearing seized which is causing the whine when the clutch isnt depressed??? Also can the throw out bearing cause a sticky clutch??? Sorry for the long post....
Old Jun 16, 2011 | 10:01 PM
BrickyardZ2003's Avatar
BrickyardZ2003
I went through a phase where I killed SEVEN (yes, 6+1!) throwout bearings in 2 years with my old Mustang - don't even ask . Hopefully the same info is right with these fancy new Z's , but yeah, it's your throwout bearing. And yes, it can cause an altered clutch feel.
Old Jun 17, 2011 | 07:09 AM
Dblock55's Avatar
Dblock55
Ok thx for the help, didn't wanna replace it and turn out to be that it wasn't it.... dunno why the second one went out.... maybe track day abuse?? Lol
Old Jun 17, 2011 | 07:11 AM
Dblock55's Avatar
Dblock55
Also if I have an.exedy clutch can I.throw on a oem bearing?? Or does it have to ne exedy
Old Jun 19, 2011 | 07:02 AM
Dblock55's Avatar
Dblock55
Bump for oem throw out bearing fitting exedy clutch?
Old Jun 23, 2011 | 06:03 PM
Dblock55's Avatar
Dblock55
ehhh
Old Jun 26, 2011 | 09:42 PM
BrickyardZ2003
Didn't know you still had unanswered questions! On my old 5.0, ANY throwout bearing could be used, OEM was always the preferred way to go. I'd look for a definite answer for that one though, man. Good luck.
Old Jun 28, 2011 | 09:31 AM
Dblock55's Avatar
Dblock55
thank you!!
Old Jun 28, 2011 | 09:52 AM
redline06's Avatar
redline06
what year is your z?
Old Jul 8, 2011 | 06:23 PM
Dblock55's Avatar
Dblock55
2004
Old Aug 1, 2011 | 03:25 PM
Dblock55's Avatar
Dblock55
So does anyone know if itll fit lol, havent gotten around to it yet but will have time soon....
Old Aug 2, 2011 | 12:58 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
more likely you need to replace clutch master/slave cylinder.
Old Aug 4, 2011 | 08:38 AM
Dblock55's Avatar
Dblock55
If it were the master/slave cylinder, then the pedal would always be getting stuck, which is not the case. I know for a fact that its the throw out bearing, just dont know if the stock one will fit on an aftermarket clutch
Old Oct 2, 2011 | 06:25 AM
Dblock55's Avatar
Dblock55
Hey all, after months of waiting on it, i finally replaced the throw out bearing, and the old one was SHOT to hell.... the center part that sits on the clutch sleeve was grinded down about an 1/4 of an inch!!! It got so hot that it was purple and had stress fractures all around the inside orifice... I had to run to the dealership to pick up a new sleeve as well because that also suffered.... thank you for your help guys.... she rides like new now... finally lol
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
