Fresh clutch, pedal wont return
Old Jul 5, 2011 | 03:57 AM
hulkout's Avatar
hulkout
Default Fresh clutch, pedal wont return
TI need help. I searched, but found nothing this specific. I just put my rebuilt engine in including a new clutch, flywheel, pilot bearing, thrust bearing and sleeve, and the cast fork and ss line. I bolted the engine in and the clutch pedal just goes to the floor and won't return unless I pull it. Any idea? Bleeding? I gotta be missing something.
Old Jul 5, 2011 | 04:52 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
It's possible one of your clutch cylinders is going out. Do you see any leaking underneath the car?
Old Jul 5, 2011 | 06:31 AM
hulkout's Avatar
hulkout
No. no leaks. Everything worked fine last october. I overboosted, bent a rod, broke 4 ringlands, and cracked a skirt pulled it out, built it, put it in yesterday, now its like this. thats what leads me to believe I missed something....
Old Jul 5, 2011 | 01:08 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Have you bled the clutch? That would be my 1st thought. Other than that... Leaks, bad master cylinder or slave. That's really all it can be.
If you pump the pedal, what happens?
Old Jul 5, 2011 | 09:08 PM
hulkout's Avatar
hulkout
I am gonna try bleedin again wednesday after work. Ill post my progress. Hopefully there will be some. By bleesing by the slave cylinder as described in the fsm, am I bleeding the master cylinder as well? Thanks for the help guys. I appreciate it.
Old Jul 6, 2011 | 08:24 AM
Vivid Racing
Vivid Racing
Yes, you're bleeding the whole system. I believe the reason for bleeding at the slave is because it's the lowest point in the system.
Old Jul 6, 2011 | 08:34 AM
SmurfZ's Avatar
SmurfZ
if bleeding the system doesnt work, you might need a new slave cylinder
Old Jul 6, 2011 | 09:33 AM
350zion's Avatar
350zion
Professional
If u can get ur hands on a Motive power bleeder it would make this a whole lot easier....
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
