Drivers side cam sensor
Old Jul 20, 2011 | 08:28 AM
brocw1093's Avatar
brocw1093
Default Drivers side cam sensor
So my car has been running the famous bad cam position sensor code for bank 2. Vdc slip and engine light come on while i get a occasional bad start. Well I ordered my drivers side sensor. I'm gonna change it and I'm just wondering does it make it a lot easier if I remove the intake manifold? And what color is the clip? I also heard you should change all 3 sensors (crank , bank 1 and bank2 ) at once. If I only change one will I end up with problems? Thanks
Old Jul 20, 2011 | 10:05 AM
str8dum1's Avatar
str8dum1
ya its alot easier with the mani off. It onlt takes 10 mins to remove/install it anyhow, so why not.
as long as your other sensors are fine, there is no need to touch them.
Old Jul 20, 2011 | 10:20 AM
brocw1093's Avatar
brocw1093
Thanks I was thinking it would go alot smoother with it off.
Old Jul 20, 2011 | 09:08 PM
Itzcashew's Avatar
Itzcashew
Honestly you can get to it without taking the Manifold off. I just lean over from the passenger side. Also having ext. on your tools help.
Old Jul 20, 2011 | 09:40 PM
brocw1093's Avatar
brocw1093
Is the clip grey
Old Jul 21, 2011 | 06:59 AM
Itzcashew's Avatar
Itzcashew
Yes it is. And the sensor is angled.
Old Jul 21, 2011 | 07:15 AM
Zazz93's Avatar
Zazz93
I've changed that sensor on the side of the road before, much quicker and easier to just go after the single 10mm bolt than to remove 15 and risk losing a bolt. Even more so if you have a plenum spacer and have to deal with the internal spacers.
Old Jul 22, 2011 | 08:04 AM
brocw1093's Avatar
brocw1093
I changed the sensor last night. Was pretty easy. I did take off the top of the manifold cuz it made it a lot easier. For anyone doing it in the future use pliers or something on the clip to push it in and pull, made it come off right away. My code went away and car is running good!
Old Jul 22, 2011 | 04:58 PM
jafulcher's Avatar
jafulcher
Its easy to reach from underneath the car.
Old Jul 22, 2011 | 04:59 PM
jafulcher's Avatar
jafulcher
You will have to remove the diffuser panel.
Old Jul 22, 2011 | 05:49 PM
Itzcashew's Avatar
Itzcashew
I captained morgan it on the tire and leaned over. Done in 5 mins.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
