Leaking diff oil? Can't pin down source
Old Jul 26, 2011 | 03:54 PM
AuAltima3.5's Avatar
AuAltima3.5
Default Leaking diff oil? Can't pin down source
Hey guys, I've got a G35 and searching a few forums I am having trouble finding help.
My differential seems to be leaking from the both the output shafts. It drips sporadically, and sometimes I can smell it. I went under the car and saw that the fluid "wet" the pumpkin from basically the lower half of each output shaft seal down. The cover is slightly wet. I've only seen three drips in my garage since I've moved. It dripped maybe four or five times in the last place I was at over the course of four months.
The output shafts are dry (where they immediately exit the diff) but just below is wetted with oil. The most oil was near the fill plug and at the bottom where it was dripping.
I tried to follow the breather tube but it kinda dissapeared into the subframe. The fill cap was just barely loose, it took another quarter turn to tighten up. I am not sure if it's common for the axle output shafts to have seals go bad? It would seem odd that both went out.
The car has 94k, diff fluid changed at 89k with valvoline syn blend. is this fluid incompatible with our diff and causing leaky seals? I am at a loss, and hoping someone with some more knowledge could chime in.
I cleaned it up with brake cleaner and hope to learn more over the next few days. I found a drip on my exhaust pipe, which I am gussing was flung onto it by the wind. It is definately gear oil and not bushing fluid.
Old Jul 26, 2011 | 04:03 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Assuming youve checked to make sure it isnt the diff bearing that is leaking....commonplace problem, tends to leave the bleed lines on the midpipe and muffler? If so, replace w solid bearing, problem solved...
Old Jul 26, 2011 | 04:08 PM
2bad240's Avatar
2bad240
when i changed my diff, i had my brother in law fill it back up, he works at jiffy lube so we did it there. i started seeing leakage from the axle stubs. so i went to check the level and he had some how put a whole extra quart in it and it was gradually leaking out.
i drained it and changed the fluid and havnt had a problem since.
Old Jul 26, 2011 | 04:51 PM
AuAltima3.5
I think I may have overfilled mine, since it was at a slight angle toward the front when i did it. I don't have access to a friggen four post lift, and don't want to take it to a shop since I don't trust most. have to get creative or find someone I can trust.
I will try to drain any excess... hopefully will solve.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
