in desperate need of help
Old Aug 9, 2011 | 01:28 PM
ncis350z's Avatar
ncis350z
Default loss of power after 3500 rpms
my 350 z was in the shop for over 3 months. nissan could not find what is wrong with it. they put in a rebuilt trans, took out my jwt clutch pressure plate and fly wheel. This was put back in after it did not solve the problem. they replaced mass airflow sensor, modual to the abs, rear left abs sensor, new spark plugs, fuel system cleaned and drained twice. took off and put back on my 20 inch tires. they thought the size and difference in tires would have been the problem but it was not. after 3 months they told me they do not know what to do with it and to take it to a speed shop and have the ecu redone. I did research on this site and thought the knox sensor and wire was the problem. so i took it in to be replaced, and all that did was cost me $710.00. did not fix the problem.
The problem is on cold start ups and on damp rainy days, the car has no power after 35-4000 rpms. when its warm it runs great. when its wet and rainy or cold, the car does not gain power. any input would be helpful. im not sure where to go from here. i have more information to offer if anyone has questions.
thanks for any and all help.
Old Aug 9, 2011 | 02:28 PM
bmccann101's Avatar
bmccann101
dont jump!!
think of your family!!
these thread titles crack me up... inb4WaizzzsaysOMGandaddsthreadlinks
Old Aug 9, 2011 | 02:30 PM
bmccann101's Avatar
bmccann101
op./.. no codes thrown? Sounds like your nissan place is pretty backwoods.
jus sayin.
Old Aug 9, 2011 | 02:43 PM
ncis350z's Avatar
ncis350z
i have a obd2 reader. before i had the knox sensor done it was reading low input bank 1 knox sensor. so i changed the sensor and wire. cleared the brain and drove the car. now it says i have an oxygen sensor out.
Old Aug 9, 2011 | 02:46 PM
350ZTheStandard's Avatar
350ZTheStandard
Finally some justice for being a Buttsburg pEElerZ fan!!!
Keep us posted
Old Aug 9, 2011 | 02:47 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Aug 9, 2011 | 02:59 PM
ncis350z's Avatar
ncis350z
i'm new to this page just trying to get help.
Old Aug 9, 2011 | 05:27 PM
z2g's Avatar
z2g
are you using an aftermarket intake or air filter?
Old Aug 9, 2011 | 05:28 PM
z2g's Avatar
z2g
im guessing on wet days somehow the moisture is getting to the maf sensor and putting car into fail safe mode
Old Aug 9, 2011 | 06:01 PM
ncis350z's Avatar
ncis350z
no the dealer put back the stock air filter.it had a k&n drop in in it.
Dr.Paulyy
Jul 29, 2019 07:45 AM
samansharif
Sep 25, 2015 12:31 PM
DeZigner
350Z Roadster
Oct 11, 2004 01:34 PM
HVN N HEL
Jan 19, 2004 04:55 PM
