how bad is this side skirt damage?
Old Aug 14, 2011 | 09:06 AM
ou8thisSN's Avatar
ou8thisSN
Default how bad is this side skirt damage?
Thought I cleared the curb, didnt. This is the result:
I know almost nothing about cars, less about damage, please give me an idea of what I can expect for this to be fixed?
Old Aug 14, 2011 | 10:44 AM
terrasmak's Avatar
Its trash, but a heat gun and a little time will make it look better.
Old Aug 14, 2011 | 10:53 AM
OkashiZ's Avatar
OkashiZ
heat it up with a heat gun and try to mold it back, do not apply too much heat or it can make it worse. use 3m double sided tape to put it all back together. Good luck.
Old Aug 14, 2011 | 11:02 AM
gvulakh's Avatar
gvulakh
Looks like you damaged the fender too unless that damage was already there. Look for used stock side skirts. Craigslist and the marketplace are your friends.
As for your fender it looks like a paintless dent removal job would be in order.
Old Aug 14, 2011 | 11:19 AM
The car is insured right? Have it repaired professionally.
Old Aug 14, 2011 | 04:13 PM
ImWeeZzel's Avatar
ImWeeZzel
upgrade to aftermarket son
Old Aug 14, 2011 | 07:07 PM
ou8thisSN's Avatar
ou8thisSN
I dont have the time or expertise to try and fix this myself. The fender damage was already there from an incident I had in my garage 6 months ago. Anyway, the car is fully insured but will they even cover it? How much would a body shop charge?
Old Aug 14, 2011 | 07:16 PM
gvulakh's Avatar
gvulakh
If you have full coverage it will be covered. But if you find used skirts and just have to have one painted and installed it may cost you less than your deductible. You might even score skirts in your color and just have to install it.
Old Aug 14, 2011 | 07:54 PM
ou8thisSN's Avatar
ou8thisSN
will an 08 skirt work on a 03?
Old Aug 14, 2011 | 07:56 PM
gvulakh's Avatar
gvulakh
Yes it should fit with no issue. Someone can correct me if I'm wrong.
Old Aug 14, 2011 | 07:59 PM
SuperBlack350z's Avatar
SuperBlack350z
you will pay a deductible, no way around it.
go check prices to see if it's worth letting the insurance know or not.
Old Aug 14, 2011 | 08:12 PM
terrasmak's Avatar
03 to 08 skirts are the same, but i would look around and just find one with the proper paint on it. Or go aftermarket.
Old Aug 15, 2011 | 09:42 AM
ou8thisSN's Avatar
ou8thisSN
went to two shops, one said that if i bring in the parts (side skirt and mudflap) they would put it on for 80 dollars, (3 hours labor)
another shop said 30 dollars to put it on (30 minutes labor). they said they can try to fix the side skirt, but wanted at least 120 to give it a shot. Now I'm looking online to find a side skirt in silver.
Old Aug 16, 2011 | 06:43 AM
JCITY's Avatar
JCITY
If it were me,and want it done right,I'd find another skirt.Installation should be a minimal cost.I agree,that given the many years that this part is interchangeable,you should be able to find one in your car color(silver-very common).
I see you live in Nashville.I'd give Doug Stewart at Crawford Z car a call.He may have that part available.Or,can find one for you/put it on.He's a great guy.His # is:
615-327-4159/1622 State St.,Nashville.
Old Aug 16, 2011 | 04:51 PM
NissanZ03's Avatar
NissanZ03
Just get used side skirts...mad easy to put on
Old Aug 17, 2011 | 02:51 PM
ou8thisSN's Avatar
ou8thisSN
in my haste, i already bought a skirt on ebay for 150. It is graphite silver, so its a darker shade than mine. I'll take it to the shop and see if they can color match it with my shade of silver.
thanks for the number, Jcity.
Old Aug 29, 2011 | 05:45 PM
ou8thisSN's Avatar
ou8thisSN
So my car is fixed. They charged me 160 bucks to paint and attach the side skirt I bought off Ebay. They also did a PDR on the dent on the fender. In all it cost about 300 and it would have been cheaper if I had bought parts from members on this forum, but I immediately bought the first skirt I saw on ebay. live and learn i suppose.
Thank you all for chiming in and your help. Im taking corners super slow now...
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
Cashwin
Oct 1, 2015 06:36 AM
