how could i flush engine oil cooler (oil)
Old Aug 16, 2011 | 09:41 PM
350z-900whp's Avatar
350z-900whp
Exclamation how could i flush engine oil cooler (oil)
hi all
i was wondering how could i flush engine oil cooler (oil)? i have setrab oilcooler from gtm oilcooler kit.
Old Aug 17, 2011 | 05:35 AM
R350Zz33's Avatar
R350Zz33
I would just change your oil then add new oil turn on the car run it for a few mins get the rpms up a lil then change the oil again and repeat till you are satisfied
Old Aug 17, 2011 | 06:20 AM
Spork's Avatar
Spork
Remove oil cooler unless you can disconnect the hoses and have plenty to play with.
One end will be held high, with oil poured into it. Use a funnel.
Other end will go into a drain pan. Use an open one like you'd use for an oil change so you can see when the fresh oil is starting to flow through.
Old Aug 17, 2011 | 06:21 AM
RandomHer0's Avatar
RandomHer0
I have the GTM oil cooler as well, just detach the lines and drain. Unless you have it mounted upside down.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
SharX59
Sep 27, 2015 09:23 AM
