06 350z rev needle bounces??
Old Aug 28, 2011 | 06:13 PM
armintheman's Avatar
armintheman
Arrow 06 350z rev needle bounces??
hey guys im not sure what the problem is but recently my rpm needle bounces alot. if i tap the gas or shift fast the rpm needle jumps. any thought on what the problem would be or how to fix it? thanks in advance
Old Aug 28, 2011 | 08:22 PM
OkashiZ's Avatar
OkashiZ
mine does that as well. but its only when i first start it.
Old Aug 28, 2011 | 10:25 PM
Several potential problems:
1. The tachometer
2. The source of the tachometer signal: CAN communication line, Unified meter and A/C amp.
Old Aug 28, 2011 | 10:29 PM
carlos350z's Avatar
carlos350z
I have that same problem on my 07.
Old Aug 28, 2011 | 10:44 PM
TravisFTW's Avatar
TravisFTW
i sort of have this problem in my 07' .. shortly after starting it, if i am rolling in 1st gear the car gets really jumpy lol .. it is wierd... but it only last about a minute and then its fine and dandy.
Old Aug 29, 2011 | 12:42 PM
Josh|Swag's Avatar
Josh|Swag
Mine does the same thing sometimes when shifting more quickly than not. Doesn't really cause anything too negative though so I'm not too worried about it.
Good luck.
Old Aug 29, 2011 | 06:14 PM
armintheman
thanks guys ya i figure it wasnt a big issue im just hoping the needle isnt loose to the point that one hard tap and it falls off the tach...lol. idk i guess it's not much of a worry. i had this problem before and once i replace the pulleys with the underdrive light weight unorthodox pulleys the car reved much faster which made the problem worse. now about to go supercharge so trying to fix the problem before forced induction...
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
Darkspy
Sep 7, 2015 09:09 PM
