:( Slip,vdc,brake, lights not turning off? help
Old Sep 5, 2011 | 09:15 AM
jcer's Avatar
jcer
Default :( Slip,vdc,brake, lights not turning off? help
Slip,vdc,brake, lights not turning off? help ,
Does any one know what I can do or have this issue before ? anything helps thanks guys.
Attached Thumbnails :( Slip,vdc,brake, lights not turning off? help-imag0497.jpg
Old Sep 5, 2011 | 09:22 AM
DavesZ#3's Avatar
DavesZ#3
Are they on when you first start the car or do they come on when you start moving?
Have you checked brake fluid level, worn pads?
Old Sep 5, 2011 | 10:35 AM
jcer's Avatar
jcer
its takes about 15-30 sec rolling
Old Sep 5, 2011 | 11:19 AM
ericjackson's Avatar
ericjackson
I would check your brake fluid
Old Sep 5, 2011 | 11:31 AM
jcer's Avatar
jcer
Ok thanks for the response I have a feeling it has something to do with my brakes but I just wanted to ask the experts here
Old Sep 5, 2011 | 11:32 AM
jcer's Avatar
jcer
but what about the slip light and traction too? would that affect all that?
Old Sep 5, 2011 | 01:01 PM
ericjackson
yeah ive been low on brake fluid and caused that before twice
Old Sep 5, 2011 | 02:17 PM
ChuckW's Avatar
ChuckW
Like it's been said, install new brake pads. The new pads will bring the brake fluid back to the required height inside of the reservoir and turn off the warining lights. If you open and waste a bottle of brake fluid, you'll just have to remove some of its volume from the reservoir when you finally do change your worm pads. No reason to create extra work.
350z82
Oct 1, 2015 06:25 PM
