Stock oil pressure gauge
Old Sep 6, 2011 | 10:12 AM
citymunky's Avatar
citymunky
Default Stock oil pressure gauge
How does the stock oil pressure gauge give the information to display the engine oil pressure? I know there is a pressure sender on the oil pan near the oil filter. Which goes to the ECU, but after that, idk. I know all 3 gauges are really one assy, but how many connector hook up? One for each gauge or one for the whole assy?
Does anybody have a pic of the back side?
Sorry for the dumb questions, I own a G35 not a 350Z.
Old Sep 6, 2011 | 05:48 PM
DavesZ#3's Avatar
DavesZ#3
I'd suggest getting a copy of the 350Z factory service manual and look in the DI section for the Triple Meter. It has complete wiring diagrams there.
Hopefully, this might tell you what you need.
Old Sep 7, 2011 | 07:15 AM
citymunky's Avatar
citymunky
Thanks, I was thinking about adding a Oil Pressure gauge to my G35. I wanted to match the OEM look and color as close as possble, so i thought a Z33's oil pressure gauge would look nice, and I wouldn't need another oil pressure sensor.
However now it's looking like it would be more trouble than it's worth.
Old Sep 8, 2011 | 07:42 AM
djamps's Avatar
djamps
I doubt the G35 uses the same sender.
Old Sep 8, 2011 | 08:00 AM
deanfootlong's Avatar
deanfootlong
you cant just connect the gauge to the sender unit. it doesnt read the same as the 350z does. its just a low pressure sensor unit. whereas the 350z uses volts to determine psi. as far as i know.
Old Sep 8, 2011 | 08:02 AM
deanfootlong
if im wrong, please inform me. id love to connect my sending unit to my zeitronix so i can display the oil pressure volts.
Old Sep 8, 2011 | 10:54 PM
citymunky's Avatar
citymunky
Maybe so, but would have been a easy fix. Needless to say i'll going with a aftermarket gauge
Old Sep 9, 2011 | 07:01 AM
str8dum1's Avatar
str8dum1
oil pressure senders are super cheap. no reason to use a stock one from a 350z. Just get the proper one for the Zeitronix
Old Sep 9, 2011 | 06:14 PM
ou8thisSN's Avatar
ou8thisSN
why do you need to know what your oil pressure gauge reads while daily driving?
Old Sep 10, 2011 | 12:24 AM
ejs0806's Avatar
ejs0806
there is just one plug on the back of the cluster its right off to the left rear in the pic right behind the screen
apex locator
Jul 23, 2021 02:27 AM
