Axle Clicking & Vent Solenoid Valve Issue
Old 09-09-2011, 11:45 AM
ThatOtherGuy
ThatOtherGuy's Avatar
Default Axle Clicking & Vent Solenoid Valve Issue
I've posted earlier about a P0455 code and I took it to a shop today and they said it was the vent solenoid valve. They want $151 for the part itself. I find that a bit drastic and unreal. Where can i find one cheaper?
Another issue I've been having is a loud clicking from the passenger side rear wheel. I took it to one shop and they said it was the brake pads. However, I find that hard to believe. I think it most likely has something to do with the "axle click issue".
Today, I took it took a different shop and they said it may be because the "drive axles are running at an angle out of spec"
I have a 2006 350z with stance coilovers and 18" rays track wheels.
66k miles.
Can someone help me with some suggestions on what to do if this were happening to you?
Old 09-09-2011, 01:32 PM
winchman
winchman's Avatar
It's probably somewhere on this page for less:
http://www.courtesyparts.com/350z-pa...5_743_746.html
Here's the troubleshooting page for that code from the '07 service manual:
DTC No. Trouble diagnosis name P0455 0455
Condition:
EVAP control system gross leak detected
EVAP control system has a very large leak such as fuel filler cap fell off, EVAP control system does not operate properly.
Possible causes:
 Fuel filler cap remains open or fails to close.
 Incorrect fuel tank vacuum relief valve
 Incorrect fuel filler cap used
 Foreign matter caught in fuel filler cap.
 Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve.
 Foreign matter caught in EVAP canister vent control valve.
 EVAP canister or fuel tank leaks
 EVAP purge line (pipe and rubber tube) leaks
 EVAP purge line rubber tube bent.
 Loose or disconnected rubber tube
 EVAP canister vent control valve and the circuit
 EVAP canister purge volume control solenoid valve and the circuit
 Fuel tank temperature sensor
 O-ring of EVAP canister vent control valve is missing or damaged.
 EVAP control system pressure sensor
 Refueling EVAP vapor cut valve
 ORVR system leaks
Old 09-09-2011, 02:16 PM
bmccann101
bmccann101's Avatar
id highly doubt its not the normal axle click we all get.
Old 09-09-2011, 03:14 PM
ThatOtherGuy
It's a constant clicking but doesnt click when turning right. It clicks even at 50+mph
Old 09-09-2011, 03:24 PM
Waiz
Waiz's Avatar
Title changed, in the future please title your threads according to the question(s) you are asking.
Old 09-09-2011, 03:50 PM
ThatOtherGuy
Sorry coach.
Old 09-09-2011, 04:44 PM
ThatOtherGuy
So where do you think I should look first?
Old 09-09-2011, 08:03 PM
winchman
winchman's Avatar
He used a double negative grammar construction to emphasize the point that he thinks it's axle click. BTW, it's not normal, but it is common.
Old 09-10-2011, 05:07 AM
ThatOtherGuy
I thought so. Hah I was just trying to make sure. I'm also not sure I should drive with the clicking for an hour at times at 65+ on the highway.
Old 09-10-2011, 12:50 PM
ThatOtherGuy
Can someone show me exactly which part is the vent solenoid valve?
Old 09-10-2011, 09:15 PM
winchman
winchman's Avatar
The diagram in the '07 service manual indicates the vent control valve is the one right next to the canister, 14920+A. The other one is the purge control valve.
I'd take a good look at gas cap and all the hoses and connections before replacing anything.
Old 09-11-2011, 05:38 AM
ThatOtherGuy
I have a 2006 z. Different motor from the 2007, unless that specific part is the exact same as the 2006?
And I've checked the hoses and gas cap multiple times before.
Old 09-11-2011, 05:41 AM
ThatOtherGuy
Just trying to make sure. It's the first z I've had..
Old 09-11-2011, 05:44 AM
winchman
winchman's Avatar
As far as I can see, the parts are the same. See:
Old 09-11-2011, 06:00 AM
ThatOtherGuy
Okay. Thank you so much.
Hopefully it solves the problem and then I can try to figure out the axle click.
Old 09-11-2011, 06:51 AM
winchman
winchman's Avatar
Here's some info on the axle click:
https://my350z.com/forum/engine-driv...rear-axle.html
http://www.notre350z.com/forum/files...ClickClack.pdf
Old 09-11-2011, 09:07 AM
ThatOtherGuy
Thank you.
Another quick question.
Is the valve located directly behind the plenum or is it under the car?
Old 09-11-2011, 09:19 AM
winchman
winchman's Avatar
It's under the right rear of the car below the fuel filler door.
Old 09-11-2011, 09:34 AM
ThatOtherGuy
Thank you so much! You've been a great help
Old 09-16-2011, 07:07 AM
ThatOtherGuy
So...I'm having an extremely difficult time removing this. I have to turn it counter clockwise from 12 to 9 and it can only be turned to about 10.5 because stuff welded to the frame is in the way.
How am I supposed to remove this valve?
Quick Reply: Axle Clicking & Vent Solenoid Valve Issue
