Anyone have a DIY for OEM Front BREMBO disc/pads?
So i took my car to the dealer to get one of the synchros checked out.. turns out it was fine but then they told me that I need new brakes... I have 1mm left of pad on my fronts and the dealer wants to charge me 1000 dollars to change them..
Screw them! Anyone have a link to a DIY for replacing the Front discs and Pads on OEM 2007-2008 Brembos? I have changed rotors and pads before on different cars but never Brembos. Any help would be great!
Oh yeah, there is also a weird noise from the tranny when i turn the car off.. it sounds like something spinning is touching something else, im thinking its the clutch still touching. Of course when i asked the dealership to adress this problem the last 3k of my warranty they totally avoid it.
http://www.youtube.com/watch?v=LZLX3jkgsJw
They are the same brakes... (g35 = 350z)
Remember that this is the "unofficial" way of changing the brake pads.
MAKE SURE that the brake fluid cap is off, and you have something around it that can absorb the brake fluid. It WILL spill over.
I just read through the section in the service manual dealing with pad replacement on Brembos. If you can't follow those instructions, you've got no business working on your own car.
Of course, that may be the case if you let the brakes on a high performance sports car get worn to half the minimum service limit without noticing it and doing something about it.
There's a sticky thread in the maintenance sub-forum that tells you where to get the FSM.
Your Z has bad synchros, a messed up clutch, and crappy brakes. Yeah, I can see how that would keep you from thinking it's a HP sports car.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
