350z sluggish
Old Oct 19, 2011 | 02:42 PM
JustAnotherZ's Avatar
JustAnotherZ
Default 350z sluggish
Hi everyone, trying to help out a buddy. He just got his Z a few months ago 2004 6 speed. He decided to take it out and tear it up anyways after a few passes on a back country road his engine started to miss really bad. He got it home and I looked into the ignition system first. I noticed his plugs were not gapped properly so I gapped the plugs other than that everything seemed to be fine. After gapping the plugs and re-installing it stopped missing but is running very sluggish it doesnt have the instant torque that it had before when you slam on the accelerator it revs up quick but doesnt pull like before... Timing issue? Maybe Knock sensor retarded timing? Anyone had this happen and have any other ideas of where we could start looking? Thanks guys!
Old Oct 19, 2011 | 03:45 PM
dvsone's Avatar
dvsone
Start off by making sure you did the correct gapping and disconnect the battery overnight.
Old Oct 19, 2011 | 04:24 PM
JustAnotherZ
Gapped at .040, and reset the ECU allready by disconnecting the pos terminal for 30 min.
Old Oct 19, 2011 | 08:20 PM
Gibbs's Avatar
Gibbs
Know it all
He may have gotten some bad gas.
Old Oct 19, 2011 | 09:08 PM
AngelsVQ's Avatar
AngelsVQ
you say it still revs up fast.... maybe the clutch is slipping
Old Oct 19, 2011 | 09:36 PM
Gibbs's Avatar
Gibbs
Know it all
I missed the part where you said it revs up quick but doesn't accelerate, that certainly sounds like a slipping clutch. As for the sputtering issue depending on how old his plugs are I might recommend just replacing the plugs and wires bc it sounds like he had a bad connection.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
