Painting My Calipers - Bleeding Brake Lines
Old Oct 22, 2011 | 09:01 AM
TreeFiddyGee's Avatar
TreeFiddyGee
Default Painting My Calipers - Bleeding Brake Lines
I am planning on removing all 4 of my brake calipers on my 2003 350z to paint them, however what is the process for removing the brake lines so that i can free the calipers?
Should i just pull it off and then drain the lines? And after all of the painting is complete, should I just reconnect the hoses, fill up the master cylinder with fluid and then use a bleeder kit to get all of the air out?
I believe that is all i would need to, but correct me if i am wrong.
Old Oct 22, 2011 | 09:13 AM
terrasmak's Avatar
Unless you really know what your doing and have a pressure bleeder, i would not disco the lines. They are a pita the bleed, even with the proper equipment.
Old Oct 22, 2011 | 09:17 AM
TreeFiddyGee
why do you say that? I've seen videos where people do it without any problems, so i wouldn't think it would be too hard.
Old Oct 22, 2011 | 02:23 PM
terrasmak's Avatar
Ive seen vids of people doing a lot of things, i can make a vid today of it, and make it seem like its easy.
Its actually easy on most cars, the Z likes to trap air in the ABS/VDC control module.
Old Oct 22, 2011 | 09:08 PM
beezee's Avatar
beezee
Read through the following thread. You will find some info on the process
https://my350z.com/forum/brakes-and-...bo-brakes.html
Old Oct 23, 2011 | 12:16 AM
TreeFiddyGee
Thank you, it helped me a lot.
Old Oct 25, 2011 | 02:12 PM
bikinilust's Avatar
bikinilust
I know a place that can powdercoat your calipers n stencil whatever logo you want for a very reasonable price. Theyve got a really fast turn around too. if interested pm me for their info.
I think they can also replace all the seals too.
mind as well seeing how you will have the calipers off anyways
